Transmission Temps??
Old Jan 23, 2012 | 10:50 AM
nlemerise's Avatar
nlemerise
Originally Posted by mueckster
This is the Derale Fluid Control Thermostat Derale Cooling Products 13011 - Derale Performance Fluid Control Thermostats - Overview - SummitRacing.com that I currently have installed to bring up my cold weather fluid temps. I am experimenting with getting my temps up a little higher to aid better mpgs. I have mine mounted to bypass the TruCool and use only the stock coolers until the additional cooling is needed.
Thanks Roland...I appreciate it. Did you see more rapid warming up of tranny fluid?
I'm going to Summit Racing in Sparks, NV this week (Thursday? 1/26/12). If anyone wants one, I am sure it can be shipped by me for a lot less than Summit will charge...I would be willing to pick one up for you. PM me if interested.
Old Jan 23, 2012 | 11:07 AM
JonathanN's Avatar
JonathanN
So, what would ideally be considered "minimum temperature" if one was to use a thermostat?
Old Jan 23, 2012 | 11:11 AM
nlemerise's Avatar
nlemerise
I do believe (but don't know as fact) that the desired target temperature is 180 degrees.
Old Jan 23, 2012 | 11:13 AM
mueckster's Avatar
mueckster
I'm going to Summit Racing in Sparks, NV this week. If anyone wants one, I am sure it can be shipped by me for a lot less than Summit will charge...I would be willing to pick one up for you. PM me if interested.
It did somewhat. To truly be more effective in getting the temps up quicker, I would need to have the thermal bypass mounted before all the coolers, or at least before the stock OTA cooler. I'm happy with it so far. The temps are up about 15*-20* more than without the bypass and I am seeing ~ 140* TFT on days above 50* ambient. I was shooting for ~ 150* minimum. Time will tell if I see any benefits in fuel economy. I've only had it on for about a month now.
Old Jan 23, 2012 | 11:26 AM
nlemerise's Avatar
nlemerise
I'm going to mount mine just after my external transmission filter which will bypass all cooling until the fluid valve closes...
Old Jan 23, 2012 | 02:25 PM
TXSailor's Avatar
TXSailor
Interesting comment/direction from Mark K. (one of our Ford FTE Experts).
I have always heard that 220 was not all that healthy so I installed a 31 row (6.0 L) cooler on my 4R100. Even towing my trans temps never hit over 190 now (even in the Davis Mountains of West TX!)
W/O towing, they run a cool 135 to 160. That's all in my Excursion of course so I can't relate to a SD........
D
Old Jan 23, 2012 | 03:01 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Does anyone remember a write-up where someone put a hydraulic fluid thermostat device in the transmission fluid line?
I've hunted all over and can't find the thread
https://www.ford-trucks.com/forums/1...mperature.html
https://www.ford-trucks.com/forums/7...l#post10773358
Old Jan 23, 2012 | 03:41 PM
JJFIVEOH's Avatar
JJFIVEOH
I haven't seen anybody mention synthetic trans fluid. I pull a 40' gooseneck that weighs approx. 12,500 pounds. I switched to https://www.amsoil.com/storefront/atd.aspx and immediately dropped 20°-25°. The worst driving conditions I have put it through was in the middle of August during rush hours traffic, stop and go for 15 miles in 98° heat and the hottest it ever got was 195°. Towing on the highway at 70MPH in the dead of summer the trans temps usually sit around 180°. I was considering upgrading the cooler because I heard the OEM cooler on a 2002 model were poor, but the synthetic fluid fixed everything. I haven't seen it hit 200° in 7 years.
Old Jan 23, 2012 | 03:42 PM
nlemerise's Avatar
nlemerise
Thanks FORDF250HDXLT for the links. I just finished reading them and from Mark Kovalsky's post in the thread, the IDEAL ATF fluid temperature is 170 degrees.
Old Jan 23, 2012 | 05:04 PM
Mike Norwood's Avatar
Mike Norwood
I never see more than 140* unless I'm towing, and then I've never seen more than190* in 100* ambient. In the winter it never gets more than130*, so I guess I need to cover my cooler up.
Old Jan 23, 2012 | 05:22 PM
sand_fiend's Avatar
sand_fiend
I too have only seen 140 while driving in so cal. Not towing.. I haven't had a chance to tow yet since i put the gauges in..
Old Jan 23, 2012 | 06:48 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Thanks FORDF250HDXLT for the links. I justr finished reading them and from Mark Kovalsky's post in the thread, the IDEAL ATF fluid temperature is 170 degrees.
Yep, I wrote that.
farmb0y
6.4L Power Stroke Diesel
Aug 14, 2011 08:42 AM
2cylguy
Jan 13, 2010 03:11 PM
shark1979
Mar 3, 2009 04:01 PM
STROKIN'IT7.3
Mar 6, 2008 07:58 AM
GoCamping
16
Jul 25, 2006 01:39 AM
