Cranking speed
Old Jan 21, 2012 | 08:18 PM
Ford_Six's Avatar
Ford_Six
Cranking speed
Should the IDI whip over like a PSD? Mine cranks really slow for about 20seconds, then speeds up and lights off. It's killing the batteries having to crank it this long, since I usually have to stop and glow it again to get it to start when it's dead cold.
Old Jan 21, 2012 | 09:16 PM
farmert's Avatar
farmert
Yes it should spin fast. It sound as if your starter is getting tired. Also take a look at the cables for any swollen or cracked isolation, that would indicate corosion in the cables. You will be surprised at the difference of a new starter.
Old Jan 21, 2012 | 09:31 PM
therifleman556's Avatar
therifleman556
DB Electrical - FORD TRUCK & CASE 6.9L 7.3L DIESEL STARTER F250 F350 1985-1994 HI TORK SND0027
I bought one of these last year. Spins that sucker over CRAZY fast.
Old Jan 21, 2012 | 10:40 PM
84-6.9L's Avatar
84-6.9L
The best thing I ever did for my old direct drive starter was get a new cable.
Old Jan 21, 2012 | 11:39 PM
IDIDieselJohn's Avatar
IDIDieselJohn
This is how fast these pigs need to crank, to fire right off.
Cold Start 1987 Ford E350 6.9 IDI Diesel Befor Winter Storage 08 - YouTube
In this older vid, it didn't fire up right up, as it had 3 bad glow plugs, so the WTS light was only coming on for 2 seconds.
Old Jan 22, 2012 | 12:41 AM
Aune163rd's Avatar
Aune163rd
John, your video dont work...
Old Jan 22, 2012 | 01:21 AM
Fireman_dave's Avatar
Fireman_dave
must crank at 200 rpms to start
Old Jan 22, 2012 | 07:40 AM
tjc transport's Avatar
tjc transport
i ain't rite
here ya go Jared.
old starter it was 70 degrees outside, new starter it was 40 degrees
old burned out starter
new starter
Old Jan 22, 2012 | 11:17 AM
Ford_Six's Avatar
Ford_Six
Ok, mine sounds like Tom's first video, then starts spinning fast before lighting off.
I'll do a voltage drop test a little later to rule out cables, likely it'll need the starter replaced though. Thanks.
Old Jan 22, 2012 | 12:22 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
mine was spinning worse than toms first vid when i first got it.my cables was obviously the problem though cus i saw black at the pass side battery.i cut that open and sure enough the green/white corrosion powder spilled out for like 6" both directions.swapped those and sounds like its running when cranking minus the rattle.
Old Jan 22, 2012 | 12:39 PM
artfd's Avatar
artfd
Exclamation
Thanks to all who posted these videos with sound. Nothing like seeing & hearing the difference between a decent starter and a so-so one.
Old Jan 22, 2012 | 12:54 PM
IDIDieselJohn
I dunno why my video ain't working, but it pretty much sounds like in Toms 2nd vid.
Old Jan 22, 2012 | 01:17 PM
artfd's Avatar
artfd
Exclamation
Your video worked for me, although I got the error message: "Embedding disabled by request" or something like that. I simply clicked through to go to YouTube and view it.
Old Jan 22, 2012 | 02:37 PM
tjc transport
i ain't rite
you really don't realize how bad the starter is until you replace it!
i swore that starter was good, until it simply would not start the truck. finally i put the spare off the shelf in and WOW!
and all my cables are less than 1 year old on that truck too.
i had the original starter rebuilt, and was going to put it on until i saw the positive cable saw split and swollen. changed the cables and it was like a new starter agin, then slowly started getting harder to start until it would not spin fast enough to start under 50 degrees.
Old Jan 22, 2012 | 02:42 PM
IDIDieselJohn
My van won't even start under 20*F, ever since the batteries went completely dead, never recovered I guess.
Cables need to be changed, and probably starter.
Exhaust View Cold Start 1985 Ford E350 6.9L Diesel Van and 1989 Straight 6 F150 - YouTube
