Stalling Problems
Old Jan 21, 2012 | 08:14 PM
Pederbuilt's Avatar
Pederbuilt
6th Gear
Stalling Problems
I've recently rebuilt my 1978 F-150 that has a 300 in it. Took the engine in and had it bored out and rebuilt, had the tranny rebuilt, new clutch, new core put in the radiator, had the carb rebuilt and cleaned, and refurbished the insisde of my cab. Since then i've done the timing... i found a previous thread telling me that they are timed from factory at 10 degrees... and basically have had it running fairly well. But it seems that every time i pull up to an intersection, i push my clutch in and when i'm almost stopped it stalls. It doesn't matter how much it has been driven prior, it stalls. Can anyone help me with this?
Old Jan 21, 2012 | 08:39 PM
devino246's Avatar
devino246
Welcome to FTE!
The clutch on these rigs isn't self adjusting. It sounds like the clutch isn't disengaging completely. How does it do when your starting it?
Old Jan 22, 2012 | 02:12 PM
Pederbuilt's Avatar
Pederbuilt
6th Gear
it always starts nice, i have a manual choke and even after it stalls it fires right back up. i'm just tired of it stalling at intersections!
Old Jan 22, 2012 | 02:56 PM
fmc400's Avatar
fmc400
MSEE
Does it stall if you coast to a stop in neutral too?
Old Jan 22, 2012 | 10:06 PM
Pederbuilt's Avatar
Pederbuilt
6th Gear
in reply to fmc400, i went out and started the truck to let it warm up, after i figured it was warm i pushed my clutch and choke all the way in and it almost died right there. i left off the clutch just leaving it in neutral and it stayed running, however it isn't running smoothly, it revs up to just a touch over a nice idle and then revs down to an almost stall and back and so forth. i tried tweaking the idle adjustment screw on my carb as well as the mixture screw, but nothing would really get rid of the change. do i have a problem inside my (supposedly cleaned and rebuilt) carb? i never did get to road test to see if it stalls in neutral yet.
Old Jan 22, 2012 | 10:33 PM
devino246's Avatar
devino246
You shouldn't be taking your choke from full to off that quickly.
Old Jan 23, 2012 | 05:54 AM
77393's Avatar
77393
Sounds like you might have a vac leak. Get some carb spray and spray it all around the intake, carb,, etc and see if the idle chages, just stay away from your exhuast. Sounds like its hunting a little bit. Did anyone set the floats in the carb?
Old Jan 24, 2012 | 10:11 PM
Pederbuilt's Avatar
Pederbuilt
6th Gear
thanks for all your input guys, once i get another day off from work i'm gonna try and put some of these suggestions to the test!
JpKimmel
19
Apr 13, 2012 04:44 AM
raycgl
Nov 16, 2008 01:14 PM
digger19
1983 - 2012 Ranger & B-Series
17
Sep 14, 2004 11:19 AM
fordmanSLO
Nov 12, 2001 10:43 PM
perrymb
Aug 11, 2001 02:58 AM
