Need quick exhaust help
Old Jan 21, 2012 | 05:43 PM
sand_fiend's Avatar
sand_fiend
I am installing my mbrs6200p 4" exhaust. I do not see anything in the instructions or on the muffler that says what direction it should flow.
On the inside of the muffler, do the louvers go in the direction of the motor to catch the sound ? or out to the back..
Old Jan 21, 2012 | 05:55 PM
binuya's Avatar
binuya
Open side of louvers pointing to the rear. I have heard you can mount it the other way and it is supposed to be quieter, but I don't know that for sure. It seems like it would also create too much drag that way.
Old Jan 21, 2012 | 06:45 PM
sand_fiend's Avatar
sand_fiend
Yes, That is what i found, or should i say my girlfriend found for me on the web. She searched the web for an answer as i cut the 34" pipe to the length i needed being a short bed. it says, if it is the other way it will work but it will cause more noise in the cab. All is good and done. Took me about 3 hr by myself. The hard part was trying to keep the pipe up to the turbo and in place with not much room. I finally used a bunge cord to strap the bottom up and was able to hook everything up..
Old Jan 21, 2012 | 11:19 PM
Bonanza35's Avatar
Bonanza35
Should of done your up pipes at the same time. Its much easier with the exhaust out of the way.
Chet
Old Jan 21, 2012 | 11:28 PM
Visseroth's Avatar
Visseroth
Yea, I had to remove the passenger's side up pipe to get my 4" installed. Might as well do the donuts while you're in there.
Old Jan 22, 2012 | 02:19 PM
Bonanza35's Avatar
Bonanza35
I just noticed my 4" is hitting somewhere. I have to get one more band clamp. One stripped out on my magnaflow exhaust. The nut they put on must of been striped or croked, I can't get the T-bolt out and new nut didn't help. I wanted 4" mega clamps but couldn't find them anywhere.
Chet
Old Jan 22, 2012 | 07:21 PM
Visseroth's Avatar
Visseroth
Chances are it'll push against the bell housing, mine does and it wanted to rub on something else but I don't recall what it is at the moment. I had to adjust the pipe as best I could to keep it from rubbing on things and had to adjust the spare tire so that it didn't rest on the exhaust pipe.
Deadbuck
Jun 13, 2018 04:10 PM
Ryan Weaver
Nov 11, 2015 01:38 AM
blackgold50
Aug 9, 2014 01:37 AM
TRAINHORNMAN
51
Dec 6, 2009 10:46 AM
Josh0525
Dec 14, 2005 03:23 PM
