Ive just begun to replace my front struts (Monroe quick strut pre-assembled)
The thing is, the top bearing plate bolts and the lower mounting point are out of alignment by 90 degrees. The included directions say they can be rotated but gives no procedure and they do not just "turn" easily obviously
Has anyone encountered this and know how to rotate them to fit??
Thanks!!
Paul
Dumb question, but you sure you rotated the top bolt pattern to the proper mating orientation? I ask because I briefly thought something similar with one of my struts. Top bolts have a specific orietation.
Installing my second Rancho Quick-Lift Strut I swore I had it oriented properly based on the angles yet it was 90 deg off. Then realized the bolt pattern really was not priented properly.
