95 EFI 460
Old Jan 20, 2012 | 03:08 PM
kedwinh's Avatar
kedwinh
95 EFI 460
Hello everyone. I usually hang out over on the 80-86 board but have a question about my motorhome. It has the 460 motor. It's been sitting for a couple years and I'm now trying to get it back up and running. My question is, how do I remove the fuel line from the rail? Want to make sure it's getting fuel from the tank but can't get them apart.
Thanks
Keith
Old Jan 20, 2012 | 03:34 PM
subford's Avatar
subford
Thanks
Keith
When you say rail do you mean frame rail or fuel manifold?
I will guess you mean fuel manifold.
I would use a fuel line removal tool, you push the fuel line in toward the fuel manifold, push the tool in and then pull the fuel line out. It is held in by a garter spring.
It also helps to twist the fuel line first to brake the "O" rings free.
The tool to use:
Old Jan 20, 2012 | 04:11 PM
merlynr's Avatar
merlynr
locate and push on schrader valve to see if you have pressure. It's on the fuel rail.
Old Jan 20, 2012 | 08:49 PM
kedwinh's Avatar
kedwinh
Thanks for the replies. Found the schrader valve, no fuel pressure. So guess I now need to find out why the pumps not working.
Old Jan 21, 2012 | 09:32 AM
merlynr's Avatar
merlynr
Do you hear anything when key is turned on like a pump sound for 2 seconds?
Old Jan 21, 2012 | 09:37 AM
subford's Avatar
subford
As you know the fuel pumps will only run for one second each time you turn on the key.
To get around this you can ground pin #6 of the self-test plug on the drivers side of the dog house and turn on the key. This will pick the fuel pump relay if the power relay was picked when the key was turned on. The Ignition switch picks the power relay.
To check for power in the fuel pump circuit use a test light that puts a load on the circuit, never use a meter as a meter will cause you to chase your tail.
With the fuel pump relay picked you should have power to the Inertia fuel shut-off switch near the steering column on the safety wall. If power is not getting passed the Inertia fuel cut-off switch try pushing the red button down on top of it. It should click if it was tripped. If no power is getting to the Inertia fuel cut-off switch with the fuel pump relay picked the you may have a open fuse.
Inertia Fuel Shut-Off Switch:
Old Jan 21, 2012 | 01:17 PM
kedwinh's Avatar
kedwinh
WOW! Thanks for the pics, they really help. Been looking for that cutoff switch. Not knowing where to look or what it looked like I wasn't having much luck. There doesn't seem to be any sound coming from the pump at all now. The other day when I pulled the relays and fuses and cleaned the contacts it did try to fire a few times. But yesterday there was nothing. And when I tripped the schrader valve with a small screwdriver there wasn't any pressure. Now that I know where that switch is, and what it looks like, and now a plan of attack I'm going to check it out some more. Thanks again guy, this is really helpful.
Old Jan 21, 2012 | 06:03 PM
kedwinh's Avatar
kedwinh
Well should have known I couldn't be that lucky. I pulled and cleaned ALL the fuses again and swapped the relays around. Found the Intertia Switch and it wasn't tripped. So grounded pin 6 on the self test plug and have power going through it. Doesn't leave to many things to check. Now just have to figure out how I'm going to get to the pump to check, and how I'm going to drop that 75gal tank if I have to. But now I know a little more about the fuel system on it.
Old Jan 21, 2012 | 10:46 PM
subford's Avatar
subford
If you do not have a black or gray tank over the the fuel tank some cut a hole in the floor of the home to get at the fuel pump.
Old Jan 22, 2012 | 06:23 AM
subford's Avatar
subford
You may also want to look at this link below if you drop the tank.
F-53 Fuel Pump Change Pictures - iRV2 Forums
Old Jan 22, 2012 | 02:56 PM
kedwinh's Avatar
kedwinh
Great link. There's no tanks above my fuel tank but it would need to be right in front of the restroom door, so it's a high traffic area. I have thought about that, but also about an aftermarket inline pump. Just don't know if it will pull thru the factor pump.
kedwinh
Jan 20, 2012 11:19 PM
Monsta
3.0L V6
Sep 17, 2010 12:59 AM
kim pursell
Jul 14, 2003 02:54 AM
DeenHylton
Oct 31, 2000 01:45 PM
DeenHylton
Oct 30, 2000 11:01 AM
