EFI 460
Old Jan 20, 2012 | 03:12 PM
kedwinh's Avatar
kedwinh
EFI 460
I posted this over on the 87+ board but thought maybe someone might know here. I have a question about my motorhome. It is a 95 with the 460 EFI motor. It's been sitting for a couple years and I'm now trying to get it back up and running. My question is, how do I remove the fuel line from the rail? Want to make sure it's getting fuel from the tank but can't get them apart.
Thanks
Keith
Old Jan 20, 2012 | 03:40 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Quck Disconnect tools, may be labeled as a/c-fuel line tools. I prefer the plastic slipover type, but some people like the metal scissor folding type, either will work, both will be a PITA. You can also check for fuel at the schrader valve on the rail, that is the fuel pressure test port. Careful, either method can put fuel everywhere you dont want to...
Old Jan 20, 2012 | 05:42 PM
Franklin2's Avatar
Franklin2
Most do have the test port on the fuel rail somewhere. It looks like a tire valve.
Old Jan 20, 2012 | 06:18 PM
ctubutis's Avatar
ctubutis
Yes, use the test port (Schrader valve), that's exactly what it's there for. Ideally, put a fuel pressure gauge on it.
Removing those quick-connects can be a PITA, and lots of plastic components are going to be fragile at this point and you risk breaking things and needing to replace them.
Old Jan 20, 2012 | 08:53 PM
kedwinh's Avatar
kedwinh
Thanks for the replies. Found the schrader valve, no fuel pressure. So guess I now need to find out why the pumps not working. Already pulled and cleaned the relay so guess next step is trace the wiring. Just hope I don't have to drop that 75gal fuel tank because it's almost full.
Old Jan 20, 2012 | 09:41 PM
ctubutis's Avatar
ctubutis
Do you have an ohm meter?
If so, put the meter on the + and - leads going to the pump; if no continuity, it's burned out.
Old Jan 20, 2012 | 11:19 PM
kedwinh's Avatar
kedwinh
Yep I got one. Never thought about checking it like that. Now just have to figure out how to get to that bugger under the motor home, sits kinda low.
vjsimone
Dec 28, 2018 08:34 AM
walt9115
Dec 31, 2013 07:02 PM
DALEDIESEL
Jan 5, 2013 08:39 AM
kedwinh
Jan 22, 2012 02:56 PM
fastbigblockford
Oct 20, 2005 08:42 PM
