What is this pump called ?
Old Jan 20, 2012 | 09:24 AM
myblkex's Avatar
myblkex
Anyone know a part # for this pump ?
I think I've narrowed down the reason for my AC/heat blowing through the defrost when reaching 50pmh or getting into the high rpms resulting from the vacuum pump not working. I checked and replaced the lines to the hubs, as well as capped them and still it flips from vents to defrost on it's own. I also checked the lines going to the back of the 3 dial on/off/selector etc.. and everything looks snug.
At this point I believe the pump has simply gone south. Does anyone have the part # for this or any info ? I don't see much listed for V10's, and most threads refer to the diesel. Any ideas or advice ?
Thanks !
Old Jan 20, 2012 | 09:53 AM
jasonodsky's Avatar
jasonodsky
This sounds like a bad vacuum canister. It stores spare vacuum for the times when the V10 is not putting out enough vacuum, like under heavy load or high rev.
It is about a $35 part from the dealer and a quick item to change. It's the large oval shaped black box behind the battery. Usually the failure is in the check valve, which is internal to the vacuum canister and can not be serviced.
I researched this and believe it was my issue too. I've replaced the vacuum canister but have not towed with it under load to confirm this fixes the problem for sure. My hub lines are capped because I have manual hubs installed.
Do a little searching here, on the F-250 and V10 forums and you should find supporting info similar to what I'm sayin'. I didn't save the thread link for reference.
Old Jan 20, 2012 | 10:38 AM
Swagtastic's Avatar
Swagtastic
Also for your info if this is for the V10 in your sig then it doesn't have a vac pump, those are on diesels only.
Old Jan 20, 2012 | 10:57 AM
myblkex's Avatar
myblkex
Yeah - that's what I thought.. but what is the device on the passenger side fender wall under the hood that the red and black hose ( which one leads to the hubs after the T ) called then ? Doesn't that create/pull the vacuum ?
I just wish I didn't have to leave my heater and ac on defrost all the time
Old Jan 20, 2012 | 11:49 AM
LivingLarge's Avatar
LivingLarge
On a v10 it's called, a vacuum solenoid.
Old Jan 20, 2012 | 01:02 PM
jasonodsky's Avatar
jasonodsky
The solenoid controls a vacuum pulse out to the hubs to tell them if they should engage or disengage. In is a certain pulse and pull and out is a different order. It don't think it creates vacuum on it's own, it controls the vacuum release to create the pulses.
Last edited by jasonodsky; Jan 20, 2012 at 01:07 PM. Reason: clarify how the solenoid works.
Old Jan 20, 2012 | 01:50 PM
myblkex's Avatar
myblkex
ahh, I see. Thanks for the clarifiaction guys. So i'm thinking then it may be like you mentioned before - the canister, since the solenoid seems to function, the canister may be the culprit.
Old Jan 20, 2012 | 02:21 PM
jasonodsky's Avatar
jasonodsky
Make sure the lines to the canister are all good with no leaks. That will rule out the lines being the failure point...plus they are alot cheaper to replace.
andy9743
Feb 16, 2017 08:36 PM
mmenzies
Nov 7, 2012 12:02 AM
plumbfishy
Nov 4, 2010 07:21 AM
King0581
Jul 22, 2008 05:10 PM
JAM2001
Jul 16, 2006 07:14 AM
