03 v10 blows out defrost only
Hey guys. Mile marker hubs on my rig. V10. Plugged 2 ports on what I thought was the vacuum pump pass side middle of the fender. The lines coming out of what I thought was the vacuum pump were molded together going into two separate ports. I plugged both ports. What did I do wrong and what should I plug?
thanks all!
thanks all!
Only diesels have separate vacuum pumps. You have a 10 cylinder vacuum pump called the engine. The item on the passenger side inside fender is called the PVH solenoid. It's job in a stock system is to supply the vacuum pulses to the hubs to lock or unlock them.
Since you've gone away from vacuum-operated hubs, identify the line going from the multi-port connector that is supposed to go to the PVH solenoid and cap it BEFORE it gets to the solenoid. The solenoids have a habit of cracking and leaking vacuum.
Check to verify vacuum at the ac module. If you have it, then the seals inside need to be replaced, or buy a new unit. The crown vics of similar eta have nearly identical modules and the seal replacement is well documented. They call it the eatc. I think it's electronic automatic temperature control.
