vacum pump problem
Old Jan 19, 2012 | 10:38 PM
old joe's Avatar
old joe
vacum pump problem
I have a 1999 F250 4x4 super duty desel my vacum pump stopped working , replaced it , still did not work , hot wired the motors, new one and the old one both work but the old one does sound bad , checked the factory wire to the pump and no power , have been looking for a bad fuse but can't find one .
Any ideas ???
<!-- / message -->
<!-- controls -->
Old Jan 19, 2012 | 11:06 PM
snakedoc's Avatar
snakedoc
if the fuses are good then a bad wire is what i would think, might try and trace the wires and see if there bad.
Old Jan 20, 2012 | 02:03 AM
carltonwebb's Avatar
carltonwebb
It is powered off of fuse 28 in the cab. Its the same fuse that does back up lights, shift interlock if automatic (lets it come out of park) , vacuum hublocks, and speed control module (cruise). If all that other stuff works, then I would say check for power and ground at the connector and see if one is lost. If cruise works, I would look really hard at the ground side of circuit as it grounds straight to body near the right battery. The cruise, vacuum, hublock and speed are all powered off the same splice near LH front of engine compartment, on upper radiator support . That is not the greatest location but all i got.
Old Jan 20, 2012 | 02:46 AM
old joe's Avatar
old joe
Great info , will give it a try , was thinking of rewiring the plug to power but will try for the ground I know I added a ground wire to the head lights and they finally got bright years ago as it was a common problem something about Canadian trucks not using a large enough ground wire !
Buy it , take it home and re-engineer it , then use it !
Old Jan 20, 2012 | 11:52 AM
old joe's Avatar
old joe
yup it was the fuse , but still won't move around the AC , there is a thing looks like a selinoid , I tapped on it and it did work once for me but seems to of quit AC is back on the windshield so I am thinking it is my problem now !
Old Jan 20, 2012 | 01:18 PM
carltonwebb
What is not working? The modes (defrost, floor etc). Or the fans?
Old Jan 20, 2012 | 01:26 PM
old joe's Avatar
old joe
seems that every thing works but the heater direction control and the vacum pump does not turn off.
think the problem is this part that has 2 vavum lines going to it , some kind of selinoid guy on here said it was a PVH solenoid , can't find one on ebay !?
Old Jan 20, 2012 | 04:52 PM
carltonwebb
Try partsguyed.com
http://www.trademotion.com/parts/199...iagram=ME99270
Old Jan 20, 2012 | 05:15 PM
old joe's Avatar
old joe
Thanks for the tip but I bought a Vacum control Solenoid at the dealer $87 with tax , was $80 on Ebay but then I would need to wait , will put it on tomorrow and hope for the best !
Gator06
Jul 18, 2018 06:24 PM
jayc3169
May 6, 2015 03:04 PM
jayc3169
May 4, 2015 05:24 PM
old joe
Feb 20, 2015 09:12 PM
radialarm
Aug 2, 2007 06:47 PM
