Sponsored by: Real Truck
vacum pump troubles
Old Jan 19, 2012 | 10:00 PM
old joe's Avatar
old joe
vacum pump troubles
I have a 1999 F250 4x4 super duty desel my vacum pump stopped working , replaced it , still did not work , hot wired the motors, new one and the old one both work but the old one does sound bad , checked the factory wire to the pump and no power , have been looking for a bad fuse but can't find one .
Any ideas ???
Old Jan 20, 2012 | 09:59 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Moved to this forum...you will get some help here.
Good luck,
Old Jan 20, 2012 | 10:02 AM
PA-Mark's Avatar
PA-Mark
does you truck have two fuse boxes like mine... the one in the pix btw... In mine there is another box in the engine bay... I would check there
Old Jan 20, 2012 | 11:50 AM
dchamberlain's Avatar
dchamberlain
The vacuum pump is on fuse 28 in the Central Junction Box under the dash. There are a number of other things running off of that fuse as well (shift lock actuator, DRL relay, vacuum hublock solenoid, speed control module, backup lamp switch and Digital Transmission Range Sensor).
So unless none of that stuff is working either, the fuse is probably OK. It wouldn't hurt to check it though.
Most likely you have a broken wire in the wiring harness. A good chance it's right at the pigtail. You could use a test light to probe the hot wire to find out. It should be hot with the key in the RUN position.
Old Jan 20, 2012 | 11:59 AM
old joe's Avatar
old joe
Well we found a bad fuse under the dash , got the pump running , won't stop though , and it still won't change the AC from windshield to straight at ya , anyway I found what looks like a selinoid bolted on the inside of the fender , 2 vacum lines going to it , I tapped it and the AC change direction but only got it to work once so am thinking this is now the problem .!?
Old Jan 20, 2012 | 12:03 PM
dchamberlain
First thing, unplug the line right at the pump. Put your finger over the nipple. The pump should stop running immediately. If it doesn't, the pump is bad.
If the pump is OK, unplug the 2 lines from the PVH (pulse vacuum hublock) solenoid. One of those lines should go to the reservoir and one should go down to the hubs. Plug the one going to the reservoir. The pump should shut off in a minute or two, as soon as it pulls down a good vacuum in the reservoir. If it does, the PVH solenoid is bad and needs replaced.
Old Feb 20, 2015 | 09:12 PM
Parts Jimmy's Avatar
Parts Jimmy
This is the problem I just experienced. The #28 fuse tested good. The smart junction box received input power from the battery but no power exited the box to the vacuum pump. The problem? Corrosion in the inside of the box. The fix? Bypass the box with a jumper. My shop foreman is an electrical genius. He enjoys electrical repairs. The box is obsolete so purchasing a new one is not possible.
rmh1999
Jun 2, 2023 11:40 PM
jferachi
Aug 15, 2021 01:40 PM
jayc3169
May 6, 2015 03:04 PM
jayc3169
May 4, 2015 05:24 PM
dpleva
Nov 10, 2006 03:58 PM
