Emergency Flasher Problem
Old Jan 19, 2012 | 06:57 PM
ffillah's Avatar
ffillah
Well, I just replaced my emergency warning flasher bezel because the red cover had been remove (exposing the bulb). Otherwise, it was working fine. So when I replace the bezel, it sparked as the bulb unit touched the spring and bezel. Now the light doesn't work. So I'm assuming I shorted something or blew a fuse.
For starters, which fuse operates the emergency flasher?
Side note: All other instrument panel lights and exterior lights still work.
Old Jan 19, 2012 | 07:11 PM
63' f100's Avatar
63' f100
I don't know, but i'd just try to replace the fuse. The are under the driver's side dash... and a mega pain in the @$$ to get too.
Old Jan 19, 2012 | 08:24 PM
camperspecial65's Avatar
camperspecial65
I believe the 4 ways are hot constantly if Im not mistaken. As to the light...did you see if you killed the bulb itself ??? its the same as the cluster bulbs...
- cs65
Old Jan 19, 2012 | 08:28 PM
ffillah's Avatar
ffillah
Yeah, I tried a new bulb - no luck. What's meant by "the 4 ways are hot constantly" - no fuse? Would that mean I shorted something out?
Old Jan 19, 2012 | 08:33 PM
camperspecial65
constant hot...can turn them on with or w/o truck running or on accy...constantly able to function regardless of engine/ignition.
- cs65
Old Jan 19, 2012 | 10:02 PM
Rgd9664's Avatar
Rgd9664
Fried relay? Im not any kind of expert but my flashers have a relay behind it. Don't know if its stock or a PO work.
Old Jan 19, 2012 | 10:26 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1965/66 F100/250: There were two different types of emergency flashers factory installed on these trucks.
There is no relay listed for either of them.
C5TZ-15B590-A .. Emergency Flasher Switch & Wiring Assy / Marked: C5TB-15B590-A or B or C / Obsolete / 1 available NOS
Applications: 1965 F100/250 2WD / 1966 F100/250 2WD before serial number 858,001.
C6TZ-13A350-A .. Emergency Flasher Switch / Marked: C6TB-13A350-A / Obsolete / 26 available NOS
Applications: 1966 F100/1100 from serial number 858,001.
Old Jan 21, 2012 | 04:53 PM
camperspecial65
there isnt any relay...only the switch and flasher unit which is seperate from the primary one in the dash harness. Occasionally you will run across flashers that have square or rectangular flashers that have been put in...round flashers are what was used as original.
- cs65
Old Jan 21, 2012 | 05:42 PM
critterf1's Avatar
critterf1
They should have a fuse. Shouldn't be hard to locate, not too many fuses were used.
Old Jan 24, 2012 | 08:06 PM
tomsrod's Avatar
tomsrod
Follow the orange wire back from the switch and you will find an in-line fuse. Open the in-line fuse assembly. You probably blew that fuse.
Old Jan 26, 2012 | 07:31 AM
ffillah's Avatar
ffillah
Bingo! Tomsrod nailed it. Just as described.
Thanks!
Old Jan 26, 2012 | 04:48 PM
tomsrod's Avatar
tomsrod
Cool!
Mandelbaum
Mar 1, 2019 12:54 PM
JoshMcClung
Jan 17, 2011 12:14 PM
PJJUN
16
Jun 2, 2005 07:50 AM
axlrose
Electrical Systems/Wiring
Nov 11, 2003 02:57 PM
cbeaur
May 9, 2003 03:54 PM
