AOD torque converter
Old Feb 23, 2012 | 09:27 PM
Conanski's Avatar
Conanski
Originally Posted by ilovemy60ford
The shift kit is the single best improvement I've made to the truck.
I'd have to agree on that.. every automatic should get one IMO.
The Converter lockup is not extreme at all and will be right at home on the street or towing a load as I do from time to time.
Technically there is no converter lockup with the AOD just a switch at the 2-3 shift from the internal coaxal input shaft to the external body of the converter, so if you are feeling another step in there that suggests something else like a band isn't letting go when it should.
Old Feb 25, 2012 | 01:26 PM
ilovemy60ford's Avatar
ilovemy60ford
Thanks, Conanski. I really just botched my terminology. What I was trying to say is that the TC launch is not extreme. Your right, there's no lockup on these.
I'm not sure I ever had a "good" stock TC to compare against, but this one is barely noticeably higher stall speed but has a significant impact on acceleration from a stop. I haven't tried pulling or hauling yet, but don't expect any trouble. I've had a couple friends mention to me that the stocker is wimpy and would likely need replaced again sometime. This one was 3 times the cost so BETTER hold up!
For good measure I threw in a trans fluid cooler in front of the radiator (inline after the radiator cooler). Was thinking I may try to get a reading on trans fluid temp some time. Is this necessary, and if so what temp is a good temp?
Old Apr 26, 2012 | 10:39 AM
championbob's Avatar
championbob
does a 1993 f150 with aod have lockup
Old Apr 26, 2012 | 10:42 AM
HemiEater's Avatar
HemiEater
If it has a button on the shifter it's an E4OD I think.. yes it has lock up..
DTexUS
39
Aug 7, 2019 09:24 AM
Hitokori
Dec 6, 2009 10:22 PM
ki4knd
Oct 21, 2009 07:18 AM
nofortunateson
General Automotive Discussion
Dec 30, 2007 10:09 AM
whateg01
Jan 21, 2007 09:06 PM
