Re-built 400 with Lifter Tick
I have a 1978 F-250 with a rebuilt 400 converted from a 351M. I added a Comp. Cam, Headers, Intake, etc. The truck runs great. I use it to tow mostly. anyway I have two problems.
First. I seem to have dry starts. When I start the engine it will tick for about 2 seconds and then stop. Is this normal?
Second. I seem to have lifter tick. I am sure they are adjusted right however they still make a little noise. Not what I would like to hear after a complete rebuild and upgrade.
Can any of you experts help guid me to a resolution?
Thanks
David McCorkle
davemc@itinet.com
Thanks
David McCorkle
davemc@itinet.com
I only see this as One problem not two.
Lifter tick.
Did you replace the check valve near the oil filter when you re-built the engine?
How long are you letting it set before re-starting it to get this tick?
Are there any oil additives in the oil?
What oil are you using ?
Lifter tick.
BTW I could of sworn the check valve on these engines was in the oil filter.
Jay_1964_F100
05-08-2002 02:31 PM
