lifter noise
Old Jul 3, 2013 | 11:23 PM
theaxt's Avatar
theaxt
lifter noise
97 351. i have faint lifter tick for about 10 seconds when i start truck in morning. is there somthing i can add to stop this
Old Jul 4, 2013 | 01:35 AM
kermmydog's Avatar
kermmydog
Add a quart of ATF the next time you change oil.
Craig
Old Jul 4, 2013 | 04:44 AM
Bob Gervais's Avatar
Bob Gervais
To expand on the above idea, add the quart of ATF before you do the oil change, run the engine for a bit, then drain. You don't wanna be running a quart of ATF permanently.
The thought behind this, is that ATF has detergents in it that help to clean internal engine parts. Sometimes when hydraulic lifters make noise, it's because they're gunked up and seize a little. More likely though, since your lifters quiet down after a short time (mine do the same thing), you've got a bad lifter that's "bleeding down", or letting all the oil out of it, overnight. Once it gets pumped up with oil again, it stops making noise.
thesuper123
Jan 27, 2019 03:31 PM
TruckDoggy
18
Jan 22, 2013 01:10 PM
Chuckymadness
17
Oct 20, 2008 10:17 AM
tombob
1978 - 1996 Big Bronco
Dec 13, 2002 07:54 AM
Ratsmoker
Feb 22, 2002 12:20 AM
