P 1391 glowplug circuit low input bank 1 ?
My 2000 just came up with a code p1391. No cel,no problems starting I just hooked up my autoenginuity to clear codes created by me replacing my battery terminal ends. I cleared codes and did a test and got p1391. It was not there before i cleared the codes. My main question is which side is bank one? I did a search and I keep seeing it refered to as right and left bank not 1 or 2. Thanks!
Thanks for the reply. Truck runs and starts fine. 22 degrees this morning the truck was pluged in. I just found an old post that says bank 1 is right side. I assume u r correct on the passenger side. Looks like I will be metering glow plugs when I get home. Will see if it starts when I leave after work today, truck is sitting all day not pluged in and it's about 15 now and temps are dropping by the minute. Hope it starts!
toreed47
05-26-2015 12:40 PM
justinlb917
45
05-24-2014 01:41 AM
JCark
11-27-2012 07:34 AM
