Maintain your COOLING SYSTEM!!!!
Old Jan 19, 2012 | 08:52 PM
Action4478's Avatar
Action4478
I don't recall miles on the truck. supposedly they only ran it for a few minutes in the shop. I am not sure I believe them!
With that much bearing damage , I would say more than a few minutes ...
Old Jan 20, 2012 | 12:40 AM
truckrider814's Avatar
truckrider814
I'm also wondering what y'all run for coolant. I have the green stuff in there now but don't know what else to use
Old Jan 20, 2012 | 06:14 AM
DIYMechanic's Avatar
DIYMechanic
I just run Prestone green with the SCA from Napa. They call it NAPA Kool.
Old Jan 20, 2012 | 02:55 PM
tjbeggs's Avatar
tjbeggs
This truck has 209K on it. Fired up like it was never even part about 30 minutes ago.
Old Jan 20, 2012 | 03:29 PM
Action4478's Avatar
Action4478
What took you so long...
Old Jan 20, 2012 | 03:44 PM
tjc transport's Avatar
tjc transport
i ain't rite
tjbeggs, with your permission i would like to do some editing on your post and then sticky this thread.
Old Jan 20, 2012 | 03:49 PM
oldbird1965's Avatar
oldbird1965
TJ, If I may ask, what parts did you replace? Cover and bearing and?
Old Jan 20, 2012 | 03:51 PM
fordpride's Avatar
fordpride
That would be nice and add what coolant and how much is preferred. How often to check SCA levels. How often is a flush is required
Old Jan 20, 2012 | 04:45 PM
tjbeggs's Avatar
tjbeggs
Had the trainee doing the work. The other trainee called in sick so I had to do his work and mine...... SISSY!!
Feel free!
We replaced the timing cover and oil pan. The bearings, though they look really bad in the pictures they weren't too bad so we left them. Time will tell how much damage really was done to injectors and HPOP. The oil pump looked perfect which is surprising considering the stop leak and coolant that went through it.
Old Jan 21, 2012 | 05:22 AM
michaloco's Avatar
michaloco
European Enthusiast
yikes... good advice. tryed to rep you for this, but i'm in jail for you
i'll change my fluid too and flush the system as well, but i can't figure out what kind of fluid i can use of them they are available here in europe. tried to search basf chemical's website, but if i reading the spec's of the fluid they recommend i'm in doubt it's the right one....
if anyone of you can help me out, it will be greatly appreciated. i will not destroy my engine
Old Jan 21, 2012 | 05:32 PM
FARM69's Avatar
FARM69
Good catch TJ.
Surely they saw the hole when they replaced the water pump? I have gotten into the habit that I inspect everything when I'm replacing something. Not only what that "part" is connecting to, but the old one as well.
As far as coolant, I've been running the Fleetguard stuff for the last several years. I think that's the name of it.... It's the one with a picture of the semi on front that's precharged.
Old Jan 25, 2012 | 11:18 PM
79f-250custom's Avatar
79f-250custom
just wondering how you sealed up that hole?!!?!
mitch
Old Jan 25, 2012 | 11:33 PM
  #28
oldbird1965
He replaced the front cover. Its refereed to as a timing cover but its not really a timing cover.
Old Jan 26, 2012 | 12:16 AM
  #29
madpogue's Avatar
madpogue
It's not? Aren't the timing gears behind it?
Old Feb 1, 2012 | 05:00 PM
  #30
73cntry's Avatar
73cntry
Originally Posted by FARM69
Good catch TJ.
I just bought a gallon of that and was wondering if that was any good. I noticed it's a redish color so I wasn't sure if it was the right stuff.
The truck does need a radiator flush though.
The green and redish can't be mixed right.
