I thought why not use stud with nuts for people who had this issue?
Studs and nuts work great for a lot of things, I do it quite often, especially with alum threads. Some things are not as easy to slide on the studs, though, but I think with the filter housing out of the way it should be doable.
Waiting for the USP to arrive today I got up the nerve to drill the holes out with a 27/64 drill bit. It was harder then i thought but I think they will be OK. I didn't want to tap them until I could look at the inserts. The inserts arrived just before dark. One of the problems drilling out the holes was trying to get light on the subject and the angle drill in there. The inserts aren't very long so I think my holes will be deep enough. They are deeper then the inserts so the tap will have enough room to make threads deep enough for the inserts, i hope. Tomorrow I'll tape the holes out and if all goes well I'll put it all together. Wish me luck!
Good luck amigo. Take it easy, your are going to make it, Im sure.
What its the thread of the outside of the inserts?
1 1/2"x 13 threads per inch tap Jose. Today I just put the tap in the hole and it seemed real tight. It might be hard to tap out, I will see, LOL. My wife is shopping for a new used pickup. I asked her what is she doing and she said that we might as well start looking. She has a lot of faith in me.
1 1/2 ??? Oh, thats very coarse thread. Looking back maybe it would be better to use helicoils in this specific case or timeserts
