Sponsored by: Auxito
4x4 not engaging
Old Jan 18, 2012 | 05:04 PM
Fseries1999's Avatar
Fseries1999
4x4 not engaging
i own a 1999 ford f150 4x4 with 174000 miles on it. when i go to activate the 4 wheel drive, it will go through 4 hi, n, nd 4 low with some fight, and will sometimes give a slight grind/pop when shifting it into low, but the light on the dash wont light up and it wont engage into 4 wheel drive. the front drive shaft spins when it is in 4 wheel drive, but no power to the wheels. i looked at the vacuum lines and the driver side line sucks air in 2 and in 4 wheel drive, but the passenger does nothing. also, the "drum" the lines connect to wont hold pressure with a vacuum tester. would my best bet be a bad seal or a sensor? or something more? hopefully someone here has experience with the same problem and how to fix it. thank you for your time.
Old Jan 18, 2012 | 09:59 PM
steve(ill)'s Avatar
steve(ill)
there are two solenoids on the firewall by the brake booster (in front of the driver). There is a vacuum hose running to the two solenoids. When you are in 2 x 4, one solenoid puts vacuum to the vacuum piston on the axle to move one direction. When you are in 4 x 4, the other solenoid puts vacuum to the vacuum piston on the axle to move the other direction. You can feel vaccuum on different hoses if you move the **** from 2 to 4 wheel drive and someone feel the hose vacuum. If you dont have vacuum on both, check the other end of hose at the solenoid to see if it is opening.
Old Jan 18, 2012 | 11:40 PM
Fseries1999
thank you, first thing im goin to check tomorrow at the shop, hopefully its nothing too major
nsaikia
2004 - 2008 F150
Apr 11, 2018 02:31 PM
Italianhb68327
2004 - 2008 F150
Dec 9, 2015 05:14 PM
Art62
2004 - 2008 F150
Mar 7, 2011 01:47 PM
BATTLIN_BLAZES
1997 - 2003 F150
Oct 9, 2007 06:01 PM
BillybobC
Jan 13, 2005 12:29 PM
