hydroboost brake convertion?
Old Jan 18, 2012 | 04:06 PM
dougbrown's Avatar
dougbrown
What is need to do this? Can I use the obs Steering pump or will I need to go sd? Anyone that has done this there info would be great. I really don't want to dump any more money into the brake system but out of things to do to fix my soft pedal. I called ford and they want 247.99 for a zero loss booster. If I.m going to spend the cash Id rather it be a one time deal!
Old Jan 18, 2012 | 04:12 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Partsguyed has the zero loss booster for $177... LINKY-- Ford Parts - www.partsguyed.com
Old Jan 18, 2012 | 04:26 PM
dougbrown's Avatar
dougbrown
Thanks Travis. Still not sure I want to go that way.
Old Jan 18, 2012 | 04:37 PM
strokin'_tatsch
I hear ya. Just saw your other thread on your brake problems. All I know about the hydro boost is you'll be using the system from the F-Superduty. Here's a couple links I dug out of the tech sticky.
https://www.ford-trucks.com/forums/9...onversion.html
Hydroboost conversion done - PowerStrokeNation : Ford Powerstroke Diesel Forum
Old Jan 19, 2012 | 07:09 AM
arkredneck's Avatar
arkredneck
I just Put hydro boost on one of my trucks the master cylinder needs modified and you will have to modify a push rod for it buy the hydroboost unit and 2 ps lines for it a couple hose clamps and some return line and a t fitting and your set
I'm pretty sure I posted a length and how I made my push rod
Old Jan 19, 2012 | 11:09 AM
dougbrown's Avatar
dougbrown
Do u have a link or pictures of what u built? I can fab one just need to figure out what I'm fabing.
Old Jan 20, 2012 | 09:56 PM
dougbrown's Avatar
dougbrown
Ordered my 97 hydro booster And hoping to make a rod tomorrow for it.
61 uni
Jul 22, 2009 10:05 AM
txtimothyt
Escape & Escape Hybrid
Oct 22, 2006 12:17 PM
