FS-2500
Old Jan 17, 2012 | 07:57 PM
JonArmy's Avatar
JonArmy
FS-2500
I've seen a couple of post were some people have talked about using the FS-2500 oil by pass system. Has anyone used this system? If so how and were did you install it and run the hoses from and to?
Old Jan 17, 2012 | 08:49 PM
Jakebrake's Avatar
Jakebrake
< Samantha...my Co-Pilot
I installed one on my truck...bought the optional oil fill adapter for the return and braided steel lines. Mounted the filter on the drivers side frame rail below the cab and snaked the lines under the degas bottle...down the area where the firewall meets the drivers side inner fender...then along the frame rail. If I remember correctly there was one hole existing in the frame rail...just had to drill the other required to bolt on the filter head. The return line for mine comes along the underside of the plastic cowl piece above the turbo to the oil fill tube adapter. Hope this helps.
superduty1967
Oct 14, 2012 08:49 PM
squaredancer
May 13, 2008 07:48 PM
Beachbumcook
Jan 3, 2007 09:07 PM
dlpinkc
Dec 31, 2004 10:06 AM
stiffysteele
Feb 20, 2004 05:13 PM
