OIL GUARD install
Old May 13, 2008 | 12:58 PM
squaredancer's Avatar
squaredancer
OIL GUARD install
Unless I fab a new bracket, installing the OIL Guard filter next to or near the main oil filter is next to impossible. At least for me. Can I safely install it about 3ft down the rail if I have enough hose ?
Old May 13, 2008 | 02:41 PM
MLCRI$I$ II's Avatar
MLCRI$I$ II
Check the gallery pictures F250_ has posted. He did some great work on his OilGuard install.
Ernie.
Old May 13, 2008 | 02:53 PM
SpringerPop's Avatar
SpringerPop
The short answer is:
Yes.
Pop
Old May 13, 2008 | 05:46 PM
mndiesel's Avatar
mndiesel
Yes you can, I put mine in the first available space on the outside side of the drivers frame rail. Used the holes already in the frame without drilling new ones. Good Luck
Old May 13, 2008 | 07:48 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Yes, i put mine on the outside of the framerail, right behind the tire. only the lower half of it seems to get sprayed from the tire, the top half is covered by the fenderliner....
Skweeker
Jul 5, 2007 11:39 AM
Beachbumcook
Nov 20, 2006 03:05 PM
hink10
May 25, 2006 11:13 PM
dahitman
May 9, 2005 05:51 PM
Groodman
Jan 27, 2005 06:25 PM
