Sponsored by: Auxito
2002 150 wont start
Old Jan 17, 2012 | 07:54 PM
herbc's Avatar
herbc
2002 150 wont start
Truck would not start two days ago. Temp was low and had under quarter tank of gas, so I thought it was a fuel issue. Put fuel addative and new gas in and got truck started. Truck had cranked over fine all day. After truck started, it died. Went to and nothing, no starter action at all. Had battery tested, good; starter tested, bad. Had starter rebuilt today, got it reinstalled, try to start truck, nothing. Starter does not even click. I'm stuck and need help. Trying to fix myself as money is tight.
Old Jan 17, 2012 | 08:45 PM
jdhudall's Avatar
jdhudall
Check your battery cables if they are loose it will not start it takes a lot of juice to turn engage the starter and if your battery terminal is loose as soon as you turn the key it will kill the connection! check both ends of your cables check your grounds both to the body and to the engine block! check your ignition fuse also!
Old Jan 17, 2012 | 08:48 PM
jdhudall's Avatar
jdhudall
They may have did a bad job on the starter maybe have to buy new one if the battery terminals are fine!
92nite351
Mar 4, 2011 03:07 PM
Giuseppe1425
Jul 24, 2009 04:46 PM
Lead_Foot
52
Dec 21, 2005 02:37 PM
cnolin
Oct 2, 2003 05:49 PM
Woodster
1983 - 2012 Ranger & B-Series
Sep 16, 2003 11:44 PM
