2000 expedition electrical problems
Old Jan 24, 2012 | 11:42 PM
alloro's Avatar
alloro
Originally Posted by kirksey228
Idk what else to check, any ideas?
What did you mean up in the 4th post when you said, "also, the front heat worked after the reverse lights and cruise control"?
Have you crawled under the truck yet to inspect the DTR (Digital Tranny Range) sensor? Perhaps road debris damaged it or the wiring under there.
Old Jan 25, 2012 | 08:24 AM
kirksey228's Avatar
kirksey228
I had to replace the heater core and after I got it all put together the reverse lights and cruise control stopped working, and very recently the heat stopped working and the fuse pops. No, I haven't where on the tranny is the dtr?
Old Jan 25, 2012 | 05:18 PM
kirksey228's Avatar
kirksey228
I put it on the lift at work( I work at Walmart tle) and cleaned connectors and inspected them and there didn't seem to be anything wrong with them
Old Jan 30, 2012 | 07:45 PM
kirksey228's Avatar
kirksey228
I'll be replacing the nss with my next check and hopefully that solves the problem.
Old Feb 4, 2012 | 05:24 PM
kirksey228's Avatar
kirksey228
Replaced it, not the problem short under the dash somewhere... helpp!!!!
Old Feb 4, 2012 | 06:13 PM
antony25's Avatar
antony25
I know you said its not the cruise but I have seen several of these with a melted servo connector.
Old Feb 4, 2012 | 07:59 PM
pdqford's Avatar
pdqford
With everything turned off, pull fuse #5 and determine which is the B+ side of the fuse socket. Then switch your meter over to continuity and check the continuity between the non-powered side of the #5 fuse socket and a good ground.
If there is continuity, that circuit is shorted to ground . . . somewhere.
Probably gonna need a wiring diagram to follow the circuit. Unplug each connector in the circuit to see when the continuity goes away. When it does, you'll know which part of the circuit is shorted.
Old Feb 4, 2012 | 08:34 PM
kirksey228's Avatar
kirksey228
Anthony25- the servo connector for climate control?
Pdqford- thank you I'll do that and get back to you on how it goes?
Old Feb 4, 2012 | 09:40 PM
antony25's Avatar
antony25
Cruise servo electrical connector.
Old Feb 4, 2012 | 11:36 PM
kirksey228's Avatar
kirksey228
Where is that located
Old Feb 6, 2012 | 09:53 PM
kirksey228's Avatar
kirksey228
Found the short! It was the blend door actuator, apparently when the heater core started leaking, it leaked into the actuator and fried it, now I just have to get the actuator and replace it. At least my reverse lights and heat work! I have yet to check the cruise control. Thanks everyone for your help!
Old Feb 7, 2012 | 02:40 PM
pdqford's Avatar
pdqford
And Thank You for reporting back with the solution
(Makes the search function much more productive!)
Old Feb 7, 2012 | 11:21 PM
  #28
kirksey228's Avatar
kirksey228
Yea, to access the actuator you need to remove the center console and the trim piece and you can see the actuator sandwiched between the hvac housing and the floor vents.
meadepc
2004 - 2008 F150
May 7, 2019 01:25 PM
bwylie
Apr 30, 2016 12:22 AM
Bloody-J
Aug 12, 2015 10:33 PM
9wire
Jan 18, 2013 06:25 PM
hmedic
Jan 1, 2013 08:04 PM
