2000 expedition electrical problems
i have a 2000 expedition and my reverse lights, cruise control, front blower motor,and my rear blower motor do not work, ive replaced fuse 5 and it keeps blowing, if i could just get pointed in the right direction or be given a solution it would be much appreciated. thank you!
Originally Posted by kirksey228
(Post 11300177)
If you don't shift to reverse, don't use the cruise control, don't use the front blower or the rear blower, does this fuse still blow? |
yes, as soon as i start the truck it pops, and if i leave it out and plug it in after i start it it pops, i thought maybe it was the blower motors but they both blow when hotwired, and i think the problem is the switches but im not sure. any ideas?
also, the front heat worked after the reverse lights and cruise control. this is frustrating the hell out of me.
Originally Posted by pdqford
(Post 11300310)
Are you replacing fuse #5 in the BDB (Battery Distribution Box - under the hood) or in the CJB (Central Junction Box - under the dash)?
im replacing number 5 under the dash
You didn't indicate which model you have, if its 4X4, if it has air suspension, or an EATC heater, but here is what fuse 5 powers:
The DRLs The Speed Control Servo The DTR (Digital Tranny Range) sensor The Function Selector Switch on the heater The Blend Door Actuator The EVO (Electronic Variable Orifice) Module (variable power assist for the steering) I'd suggest getting a wiring diagram so you can find an appropriate spot to disconnect all these items and see if the fuse still blows. If it doesn't, then connect up one more of these items until the fuse blows. Then you'll know what circuit to concentrate on. BTW, has your Expy had the Cruise Control wiring recall fixed by the dealer to prevent a fire? |
It is a 4x4 and it does not have air suspension. Is eatc electronic air temperature control? If so it does not have it. I have a repair manual for it but I don't think it has the wiring diagram for fuses. Is there a specific place I can look for that? And I just purchased it in June so I'm not sure, is that a huge risk?
The most likely suspect is one of the 2 blower motor speed resistors. One of the resistive coils could've broke and is shorting to ground. You can test this theory by unplugging the connector going to each of the speed resistors and seeing if the fuse holds.
(Post 11311099)
(Post 11311099)
(Post 11311099)
(And some of the earlier modifications were recalled again for an 'improved' wiring harness modification.) |
Originally Posted by alloro
(Post 11311450)
and thamkyou both for your help i should be able to get to it in the next couple days and ill get back on here. |
(Post 11324173)
do you have an idea where the resistor is under the dash?
is there a way to bypass it or should i just replace the resistor?
Just unplug the connector to see if the fuse stops blowing. If it does then change the resistor. Do this same test with the rear blower too.
Its not the speed resistors, the switches, or the cruise control. Idk what else to check, any ideas? Thank you for your helps so far it is very much appreciated!
