Sponsored by: Auxito
Flashing Over Drive Light, Dead Speedometer/Odometer
Old Jan 16, 2012 | 11:47 PM
proggod's Avatar
proggod
I reprogrammed my computer, to get rid of a bad tune with the Ford Program. After reprogramming, and entering in my tire size/gear size my speedometer and odometer no longer work. Also my overdrive light is flashing. Does this truck have a PSOM and could that be bad? What else could cause the problem, it definitely happened when it was flashed. Whats the cheapest way to fix it?
Old Jan 17, 2012 | 01:16 AM
Bluegrass 7's Avatar
Bluegrass 7
Return to the stock program and consult the program vendor.
We have no way to provide any advice other than ask what trans code was triggered to see what part of the program was altered to cause the issues..
Even then what would you do about it but return to the stock program.
Good luck.
Old Jan 17, 2012 | 08:44 AM
proggod's Avatar
proggod
Flashing the computer to stock is what caused the issue, using the Ford program. By the ford program, I mean the same one the dealer uses. Dealer said it could bad dashboard, but would that make the overdrive light go on, and why would that go bad during programming?
Old Jan 17, 2012 | 11:49 AM
92nite351's Avatar
92nite351
is the truck throwing any other code? start there and make sure all the systems are working.. if the speedsensor was bad the CEL would be on, if any of the circuits are bad CEL will be on..
Old Jan 17, 2012 | 01:20 PM
Bluegrass 7
Well, you got into a situation by playing with the program.
It's no use asking questions why until after the situation is sorted out and you see what had to be done.
No one has all the answers at this point.
Start by trying to get the code for the transmission to see what might have been corrupted in the program or maybe there is a failure of coinidence.
If the PCM has been reflashes to stock, there should be no problem unless a failure has taken place with some other area.
The keys and Pats aso have to be reprogrammed seperate.
The OD lamp is flashed by the PCM from a logic set after it detects an issue coming back on the harness from the transmission that involoves the shift solenoids, lockup, the DTR, speed sensing and the temp sensor in the trans.
Good luck with it.
Old Jan 17, 2012 | 01:58 PM
galaxie641's Avatar
galaxie641
Is this a 99+?
Old Jan 17, 2012 | 06:55 PM
proggod's Avatar
proggod
Originally Posted by galaxie641
Is this a 99+?
Yes this is a 2002
The biggest question is does this truck have a PSOM, and is that part off the dashboard. Dealer said that dashboard needs to be replaced but would that trigger the overdrive light. If the PSOM is part of dash gauges I could see that being the problem, however if its not, then replacing the dash gauge pod would be a huge waste of money, and not fix the problem.
Old Jan 23, 2013 | 09:42 PM
proggod's Avatar
proggod
I have still yet to fix my issue, i don't suppose anyone has anything else to add?
Old Jan 24, 2013 | 07:06 AM
MIKE 04 GT's Avatar
MIKE 04 GT
i dont know about PSOM, but the OD flashing is like the Check engine Alight for the trans, try to figure out what the codes are for the transmission and go from there. i think your trans is fine since it started with the reprogram. what was wrong with the other program to make you reprogram?
Old Jan 24, 2013 | 01:47 PM
Bluegrass 7
In my reply #5 I gave you the operation for the transmission.
There is no stand alone trans controller.
The PCM does all the monitoring of the electrical trans functions and reports via the shift lever light and PCM code.
As it is now, I fail to understand why the dash has to be 'replaced' just for a reflash unless some fault was proven with the dash.
Playing with aftermarket programs puts any user out on a limb with the hope nothing happens. Most are lucky but some are not.
Good luck.
Deluxe46
Sep 12, 2019 10:17 PM
cowgrlkm
1983 - 2012 Ranger & B-Series
Mar 24, 2008 08:20 PM
MikeSDK
Nov 17, 2006 02:06 PM
onedangerouswookie
1997 - 2003 F150
Nov 21, 2004 10:04 AM
MARK7164
Mar 30, 2004 08:02 PM
