Fuel drain valve o-rings size?
I not going order from internet or buy from dealer.
I would like know what size and it ok to use viton o-ring? I can get like 25 packs for under $7 at Grainger while other places charge $5-12 for 2 o-rings.
Reason why I need o-rings. Mine POP leak no idea how long it was leak. Happened like 1 month when I found mpg from 17 DROP to 14 mpg. It leak so much diesel out that drain valve.
Yesterday I pour 5 gallons of hot water to wash diesel stain on fuel filter cap to inspect where leak. It come from bottom of drain valve.
Here, scroll down a bit and you'll see fuel drain o-rings, this should help you more Click here Ford Super Duty Powerstroke Part Numbers | Superdutypsd.com
RattlerHilldiesel
20
08-28-2009 10:17 AM
kkdad7.3
13
10-22-2007 03:20 PM
