help, fuel leak.
Old Mar 12, 2007 | 01:02 PM
crack's Avatar
crack
help, fuel leak.
ive had my truck parked for a couple days, and today I had to go jumpstart a buddies car. when I got to his car I noticed a leak under my truck. smelt it and it was fuel. looked around for the leak couldnt really find a source. could see it pooled up in the engine valley.perhaps the fuel bowl cap thing came a bit loose?
Old Mar 12, 2007 | 01:09 PM
Pocket's Avatar
Pocket
Have you swapped out the drain valve o-rings yet?
Old Mar 12, 2007 | 01:53 PM
crack's Avatar
crack
ha, no, I wasnt aware that I should?
Old Mar 12, 2007 | 01:58 PM
F250_'s Avatar
F250_
It could be either the filter cap's o-ring, or the drain valve o-rings, which is most likely. The new ULSD that's hitting the pumps all over seems to be causing the older o-rings to loose some of their swelling and is beginning to cause some leaks.
Here's the linnk to Pure Diesel Power for a $12 kit to fix the drain valve issue (if that's where it's coming from).
http://www.puredieselpower.com/catal...ngs-p-103.html
Old Mar 12, 2007 | 02:01 PM
John311t's Avatar
John311t
That ULSD causes a lot of problems. Stupid tree hugger owe us some money.
