Cam break in
Old Jan 16, 2012 | 03:06 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
Cam break in
I got my 390 back from the shop thursday, dropped it in and fired it up last night. 5 minutes into break-in the alternator belt snapped, I shut it down quick before it had a chance to overheat. As it turns out the spacer behind the alternator was missing. The alternator moved back, overheating the belt and snapping it. So i put one together a spacer real quick out of some stuff laying around, and fired it back up with another belt I had behind the seat. I ran it for the full 30 minutes at 2500 RPM, no other issues. I fired it up today and ran it for about a half hour, varying the rpm, per my machinist instructions, it seems to run ok.
How long will it be before I know if I killed my cam?
Sam
Old Jan 16, 2012 | 04:15 PM
RKDxpress's Avatar
RKDxpress
I bet it will be just fine . I've had mine stall out after a few minutes had to adjust dist hold down retime it. Then finish break in.
Old Jan 16, 2012 | 05:24 PM
MIKES 68 F100's Avatar
MIKES 68 F100
should be ok , as long as you turned it off right away then resumed break in on next start up. i know scarey stuff
Old Jan 16, 2012 | 05:40 PM
Rusty_Old_F250
Thanks guys, that helps put my mind at ease! And when it happened it got shut off quick, and the second it started again it was right back to 2500 RPM.
It is scary stuff! This is my first re-build, and I will be happy once this thing is all done.
Sam
Old Jan 16, 2012 | 06:41 PM
69cj's Avatar
69cj
Your break in is fine. Part of procedure during break in is to check for leaks etc. and shut down if theres a problem and then fire it back up.
Old Jan 22, 2012 | 12:29 AM
Rusty_Old_F250
You guys were right, I drove it for the first time today and it ran just fine! Sure feels good to have my truck on the road again.
Sam
riggers
Jan 24, 2015 10:16 AM
ScottInTexas
1997 - 2003 F150
Feb 23, 2009 05:07 AM
kjmdrumz3
Jan 11, 2009 09:28 PM
Ruckus1
2004 - 2008 F150
Dec 13, 2008 10:19 PM
MJEmerson
3.8 & 4.2L V6
Feb 2, 2004 05:19 AM
