390 intake question
Old Jan 19, 2012 | 08:12 AM
SeaBeeCm1's Avatar
SeaBeeCm1
390 intake question
so I have a 390 2 barrel and with a empty pocket want to upgrade to a 4 barrel intake. I have found a factory steel intake for $50 would this be a good way to go if so what carbuerator should I be looking for Thanks
Old Jan 19, 2012 | 08:54 AM
MIKES 68 F100's Avatar
MIKES 68 F100
$50.00 sounds fair for a steel intake ,do you know what number it is
a s or a t is a "better manifold " search craigslist always aluminum intakes on there , i scored a performer for $80 if motor is stock a 500-600 cfm will work just fine again check craigslist .
Old Jan 19, 2012 | 12:45 PM
Bear 45/70's Avatar
Bear 45/70
Iron intake, the only steel intake were experimental jobs.
Old Jan 19, 2012 | 12:55 PM
MIKES 68 F100
yeah , yeah if you want to be exact
Old Jan 19, 2012 | 01:03 PM
Bear 45/70's Avatar
Bear 45/70
No, just correct. You make steel from iron. You can not make iron from steel.
Old Jan 19, 2012 | 01:08 PM
MIKES 68 F100
relax , op and i know the diff just not worried about it .
Old Jan 19, 2012 | 01:11 PM
Bear 45/70's Avatar
Bear 45/70
And your reasoning is why the internet is full of bad info. Noobees come along and see this post and now think that there are steel intakes.
Old Jan 19, 2012 | 02:09 PM
85e150's Avatar
85e150
But isn't an iron manifold a steal compared to aluminum?
Old Jan 19, 2012 | 02:20 PM
MIKES 68 F100
dont' "poke the bear" lol
Old Jan 19, 2012 | 02:29 PM
Bear 45/70's Avatar
Bear 45/70
Old Jan 20, 2012 | 07:14 AM
baddad457's Avatar
baddad457
Not when you drop it on your foot, or throw out your back trying to get it set in place on the engine without disturbing the gaskets.
Old Jan 21, 2012 | 04:19 PM
UNTAMND's Avatar
UNTAMND
hahahaha definatly can throw your back out AND THEN drop it on your foot if youre not careful
yes that iron intake will be fine for a 4barrel swap on your engine as long as youre not concerned about weight
it will flow and perform just fine for a mild cam engine. if youre engine is stock or even mild and only rev to 6k then a 600 cfm carb is plenty and it will give you good throttle responce.
Old Jan 22, 2012 | 06:08 AM
SeaBeeCm1's Avatar
SeaBeeCm1
okey dokey picked up the manifold and also as a bonus a set of headers for the 390 for $50 so now on to search for a carbuerator
Old Jan 22, 2012 | 07:18 AM
UNTAMND's Avatar
UNTAMND
Cool. That seems like a good deal.
What do you have for a motor. What trans.
Like was asked earlier, what is the casting letter, if any, is on it. There may be an S or a T on it. Just curious. Any of them are better then a 2barrel.
Do you prefer edelbrock or Holley carb.
Old Jan 22, 2012 | 07:24 AM
SeaBeeCm1's Avatar
SeaBeeCm1
There is a ca and 5e numbers on it it is a 390 dont know if it is a deal or not but there is a holley 650 on craigslist for $40
