Headlight conversion
Old May 2, 2012 | 07:21 PM
  #31
RACERX7775's Avatar
RACERX7775
Originally Posted by aortizexcursion
I believe racer has bi-xenon headlights. He'll be able to explain to you how his high beams operate.
I do. They are Bi-xenon headlights. The best headlights made are the Acura TL projectors. It operates by means of a solenoid that actually moves the shield (that controls beam pattern) up out of the way. That makes 100% of the bulb light reflect out of the projector. The wiring is simply using your high beam wiring from the factory truck to activate the solenoid. With doing it this way, you will have to make sure that your low beams are ALWAYS on with the headlights. Bi-xenon HID's do not have a different bulb for high and low. There is only one intensity for the bulb. You don't need a brighter bulb for high beams, just the proper use of what light is being made by the HID.
Old May 3, 2012 | 12:04 PM
  #32
Curt's05's Avatar
Curt's05
Wiser by FTE
X-V10r mine are from from LMC truck.com one piece in black or chrome or projectors for about $300.00 for the set. copy.Catalog Search
Ryan50hrl
2004 - 2008 F150
18
Nov 10, 2009 02:45 AM
86F150302
51
Jan 19, 2009 03:56 AM
jleinweber
May 28, 2005 06:10 PM
steve381
Bronco II
Feb 26, 2005 03:08 PM
Monty06
Bronco II
Feb 24, 2005 09:32 PM
