New Truck + Curb. Help!
Old 01-15-2012, 10:05 PM
silvercoal's Avatar
silvercoal
silvercoal is offline
Hey guys, coming to you from Michigans UP. I picked up a 1990 F250 7.3 IDI with 122k on the ticker tonight for $1500. Yeah, shes got some cancer pretty good but the truck was purchased locally and sold in the same town. Truck runs great. Extended Cab Longbox with a nice Lund Topper. New glow plugs and manual toggle, newer batteries. How'd I do on price? Lockouts are good, and 4 wheel works seamlessly, well it did.
So, I was pulling in back home with a couple buddies who went with me to get it and against my better judgement they convinced me to plow through a snowbank in the parking lot. However, there was a pretty good curb hidden under the front of the bank and the truck didn't like that.
It now clunks here and there when in 4 hi/low and is perfectly fine when in 2 wheel. I haven't inspected much as it was dark, besides trying to wiggle the front driveshaft which doesn't have much play and I can spin it easily with my hand. I'm thinking U joint as it sounds like it is binding. Could it just need to be greased and the curb caused it to bind a bit? Thought maybe someone could help me diagnose the problem....
Thanks in advance!
Old 01-15-2012, 11:07 PM
Hotshot869's Avatar
Hotshot869
Hotshot869 is offline
My girlfriends truck, soon to be my truck! is a 89' F350, 7.3 IDI. it clunks when in 4WD as well, but not in 2WD. I've looked it over and concluded the front U-joint needed to be replaced. Swapped it out and now no clunking. Could be a thought. Good luck with the diagnosis.
Old 01-16-2012, 09:21 AM
mpc07005's Avatar
mpc07005
mpc07005 is offline
How'd you do on price? Well I paid $2100 for my '93 F250 gasser with 157000 miles, and I got a good deal! When you say [the cancer is] bad, how bad are we talking? Around me (Connecticut), that truck goes for ~3500-4800 easy. That 250 has a TTB up front, so 2 Us on the driveshaft and 3 an the axles, plus a lot of extra bracketry to bend dead center. Check the radius arm bushings, brackets, and radius arms themselves in addition to the ujoints. I just did a D60 SAS because I had a busted bracket, old balljoints, and I got a good axle cheep.
-Mike
Old 01-16-2012, 11:50 AM
deljac's Avatar
deljac
deljac is offline
wlecome to the site sounds like you got a good deal on your truck. try the u-joints first. what town in the U P you from. i have family in fairport
Old 01-16-2012, 12:13 PM
silvercoal's Avatar
silvercoal
thanks for the replies. it was the outer stub shaft. im going to replace that and the joint, hope the inner one is ok. so, anyone got one laying around? its a dana 50. im a student at michigan tech in houghton, the u.p. is unbeatable.
Austin Cheeney
13
03-08-2017 10:25 AM
ngagnej
10-31-2011 01:21 PM
hhowell1990
12-10-2010 02:04 PM
josiah
09-09-2003 10:38 PM
BlueTorpedo85
05-14-2003 11:58 AM
Quick Reply: New Truck + Curb. Help!
