T-stat neck
Old Jan 17, 2012 | 01:35 PM
DIYMechanic's Avatar
DIYMechanic
I think the OBS neck is a couple inches shorter than the SD neck.
Old Jan 17, 2012 | 01:39 PM
bad12jr's Avatar
bad12jr
You know it may be. I didn't really check that. I'll have to look. I checked diameter and bolt pattern which were the same. My hosed reached but I'll check and let ya know if they are the same.
Old Jan 17, 2012 | 03:24 PM
fordpride's Avatar
fordpride
The SD one is shorter but I'm thinking I can use it the the SD upper rad. hose but I may be wrong I'll have to look at brother n laws SD
http://www.dieselsite.com/blackbille...athousing.aspx
Old Jan 17, 2012 | 04:10 PM
LeoJr's Avatar
LeoJr
Does anyone know the bolt hole spacing and outside diameter of the neck at the flange end? I may have a strengthening washer cut out of some 1/4" plate.
Old Jan 17, 2012 | 07:02 PM
strokin'_tatsch's Avatar
strokin'_tatsch
I have the T-Stat housing reinforcement ring that Nate posted earlier in this thread on my truck. It works great. My stock housing leaked for about 3 years very very slowly before I went ahead and got a new housing and the reinforcement ring.
Old Jan 17, 2012 | 07:24 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Originally Posted by DIYMechanic
I don't know if the SD billet housings will work for the OBS or not, but I know that these are supposed to help keep the stock neck tight and dry.
T-Stat Housing Ring
The last pic is what Nate linked, Or you can fab yours or buy an aluminum neck
Old Jan 17, 2012 | 07:39 PM
fordpride's Avatar
fordpride
If you look in the last pic that Jose posted The seam above the reinforcement ring is were mine is leaking
Old Jan 18, 2012 | 12:06 PM
strokin'_tatsch
Jose, can that aluminum water neck be bought somewhere? I would like to know where to get one of those. That's pretty slick looking.
Old Jan 18, 2012 | 02:48 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Red face
No I dont think so, IIRC was custom made for someone in the forums.
Old Jan 18, 2012 | 05:03 PM
quesey's Avatar
quesey
was thinking the same thing
Unrealo4
6.7L Power Stroke Diesel
Jul 31, 2019 10:59 PM
hillcountryflt
Jul 30, 2014 07:01 PM
pminne
15
Mar 7, 2011 08:07 AM
K man
Mar 4, 2007 04:14 AM
slonkey
1983 - 2012 Ranger & B-Series
Sep 3, 2005 11:11 AM
