I'm looking for Turbo spec's fopr a stock turbo on a 03' f-250 6.0l. Just wantting to compare different Turbos but cant seem to find the spec todo so.
Also looking for a location for the EBP and Map sensors to check for issues. Thanks a ton if you have/know were the info is.
I posted a pic of the ebp sensor in the other thread
I dont have a pic of the Map sensor but its on the passenger side on a braket thats bolted to the heater fan assembly with a black hose that comes from the intake manafold
1 more thing being you have an 03 your truck doesnt use EBP in the programming for the Turbo control
Nothing is really wrong besides issues Ive already posted in others threads. Now im just looking for things I need to look after to keep it running Beastly!!! Cant have a POS in my line of work. And im the type I need to know everything that I can learn so I have the best around ! So, now im just trying to find the little stuff before it becomes big stuff! That and It's my first Powerstoke so need all the info i can find so my truck last. And im not shy to ask the wrong question. so long as I learn from it and move on. That and I cant work on something I dont know, so until I learn the bascis Im not comfrontable to work on something I dont know.
Oh and yes i have gauges, running a CTS evo Programmer, It has almost every bit of data you can pull from the obd plug, not the best tuner but works just fine for being stock!
didnt buy it for the tunes really just the ablity to see whats happening to the motor/pulling codes/etc...
Well ive looked in the tech folder but to no avil it doesnt help atm. I could use the spreedsheet also. Im new to the game so slide me anything you think will keep me out front of my probelms would be SWEET!!! And ive been reading post from this site for weeks to help solve a problem and think ive found my issues. but cant fix them til tomorrow when i can get parts. so im sure ill have a post going tomorrow on my fixes/problems from there. kinda excited to see if these planed fixes make my baby run like a beast again, sure it will eventually.
ok good for turbo concerns with the sensors that control them you will need to compare MAP,EBP and BARO at KOEO they need to be within .5 psi of each other
You maynot get EBP IDK if they give it a newer flash of the PCM Stratigy at Ford if it will use EBP then. My 03 Doesnot use EBP either
