low beam headlights not working
Old Jan 15, 2012 | 07:22 PM
theenforcer's Avatar
theenforcer
gday guys
could anyone help me with this problem, i have checked the two 10amp fuses under the bonnet but are intact, i think it could be the switch but dont want to replace it without maybe being able to check everything.
does anyone have some ideas of where to start and what to check.
thanks in advance
cheers josh.
Old Jan 15, 2012 | 08:02 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Here's the head light prints for a 2003 F250 is the best I can do for ya.
Old Jan 15, 2012 | 11:04 PM
theenforcer
thanks for that mate, ill start checking everything
cheers
josh
Old Jan 16, 2012 | 12:14 AM
js139's Avatar
js139
I know this may sound crazy, but I have seen this twice. Try replacing one bulb and see if the lows work with the new bulb. I have seen on two trucks the low beams go out at the same exact time. I would love to know the odds of that as it has to be rare, however both times the high beams worked, but the lows didn't. It would be a good thing to check before you start tearing into everything. Just an idea.
Old Jan 20, 2012 | 04:31 PM
theenforcer
thanks for the heads up. i havint had a chance to do anything yet and that did cross my mind when it first happened i have some spare globes so i will give that a shot first. if it works i will let you know..
cheers mate
josh.
Old Feb 4, 2012 | 02:53 AM
theenforcer
hey js i swapped over the globes yesterday and that fixed it. thanks for the heads up as i wasint looking forward to pulling everything apart.
cheers mate
josh
Bad Bird
Apr 9, 2012 06:38 AM
highteckredneck
1997 - 2003 F150
May 19, 2010 01:55 PM
HUNTER10
Oct 4, 2009 07:40 AM
grams72
Sep 22, 2009 02:16 AM
dend89
Feb 13, 2003 11:39 PM
