HELP, Headlight doesn't work?
Old Oct 3, 2009 | 04:06 PM
HUNTER10's Avatar
HUNTER10
Hey guys, I have an 01 Ford F250 crew cab lariet diesel with around 189,000 miles on it. Just recently (last couple nights) my passanger side headlight as stopped working when the low beams are on. The driver side headlight and fog lights on both sides work fine though. And when I turn the highbeams on - both headlights work fine? So obviously I guess its not the bulb being as it works on high beams. Any thoughts as to what is wrong with it. Thanks.
Old Oct 3, 2009 | 05:40 PM
rbaker6336's Avatar
rbaker6336
Check your fuses you should find a bad one
In the power distribution box under the hood
Fuse 11 10A* Right Headlamp (Low Beam)
Old Oct 3, 2009 | 05:51 PM
farmdad's Avatar
farmdad
The low beam filament could be burned out.
Old Oct 3, 2009 | 06:25 PM
rbaker6336's Avatar
rbaker6336
yep guess I read something that wasn't there
Check the fuses (easier than the bulb) if that's not it check the bulb.It has two elements (low and high beam).One can burn out without the other
Old Oct 3, 2009 | 10:38 PM
F350-6's Avatar
F350-6
I'd say it's time to change the bulb. Since the high beams still work, that tells me your wiring is fine.
Old Oct 3, 2009 | 11:06 PM
megawatt00's Avatar
megawatt00
Agreed.......
Old Oct 3, 2009 | 11:31 PM
PwerStroke99's Avatar
PwerStroke99
Its a burnt bulb. If the fuse was bad, none of the headlights would work. Easy fix, new bulb, but change them out in pairs, because if u only change one, the other one will burn out shortly after that.
Old Oct 3, 2009 | 11:46 PM
F350-6's Avatar
F350-6
No offense, but I'd like to disagree here. I've changed my drivers side bulb 2 times now, but never touched the passenger side (at least until I opened my big mouth. Now we'll have to see what Monday brings. )
Old Oct 4, 2009 | 12:01 AM
WA.Ranger's Avatar
WA.Ranger
X2. There easy enough to change. I always carry spares behind my seat when needed. You can pick up Silverstars on amazon.com very cheap compared to walmart ot any auto parts store. You can also pick up a set of 9005's for your fog lights if you have them. Makes a differance.
Oh, almost forgot, there's a $5 rebate on them right now also.
Amazon.com: Sylvania 9007ST BP TWIN SilverStar High Performance Halogen Headlight - Pack of 2: Automotive
Old Oct 4, 2009 | 12:08 AM
PwerStroke99
Well, we will definitely agree to disagree, lol. I have seen it happen many times.
Old Oct 4, 2009 | 07:40 AM
rbaker6336's Avatar
rbaker6336
I beg to differ,there is a fuse for each low beam
Fuse 9 10A* Left Headlamp (Low Beam)
mechasus
Escape & Escape Hybrid
Oct 25, 2021 04:06 PM
Bleishear
Electrical Systems/Wiring
Oct 26, 2018 07:03 PM
deano2
19
Feb 17, 2018 08:51 AM
muscletruck7379
General Automotive Discussion
Jul 9, 2012 06:19 PM
Weezman
1978 - 1996 Big Bronco
Sep 9, 2008 05:04 PM
