Aftermarket Gas Tank
Old 01-15-2012, 10:25 AM
Rick_Fury's Avatar
Rick_Fury
Rick_Fury is offline
I need a new gas tank for my 1983 F150. Are the replacement aftermarket gas tanks decent? My local NAPA store sells a replacement tank, and I was wondering if anyone can tell me if the quality is as good or better than the stock tank?
Old 01-15-2012, 11:28 AM
smashclash's Avatar
smashclash
smashclash is offline
I had to replace both tanks in my truck. I bought them from Advance. They are spectra brand. While I had them out I replaced the sending units as well. The only issue had was on one of the tanks the notches cut out for the fuel sending unit were in the wrong place. (They should have been at 9 and 2 o'clock but where at 10 and 3 o'clock or something along those lines. I put new notches in and have had no issues. Been about a year and a half).
Old 01-15-2012, 11:34 AM
RyansFord10's Avatar
RyansFord10
RyansFord10 is offline
@Smashclash
Would it be cheaper for me to clean out my rear gas tank because it has old gas in it, the pump is out, and its got rust in it... or would it be cheaper for me to by a new rear gas tank?
How much was your new rear gas tank at Advance?
Old 01-15-2012, 01:08 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,703 Likes on 1,377 Posts
New tank is only around $100. Do you think you can really get the old tank clean enough? And where do you think the rust came from? The tank correct? How thin and how many pinholes is it going to have after you get it cleaned out(if you can).
Old 01-15-2012, 02:38 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
I tried to get the rust out of a tank as follows:
  • Dropped tank and poured out all gas
  • Put in 2 gallons of new gas as well as a heavy chain and sloshed it hard for as long as our arms could go
  • Poured that out and put another 2 gallons in awa chain and sloshed again
  • Did the above one more time
  • poured that out, reinstalled tank and filled with new gas
The tank looked good, but put out so much rust that it plugged the accelerator pump nozzles. I ran two see-thru plastic filters and had to change them frequently, particularly the first one but even the second one a few times.
Old 01-15-2012, 02:49 PM
smashclash's Avatar
smashclash
my tanks rusted out on the top of them. There were holes in the top and eventually they worked their way down the sides. When I got the new ones I painted them with undercoat before installing them.
As for cost I think it was around $100. Spend some time looking around though. Advance (if you go with them) has a lot of discount codes if you google them.
Old 01-15-2012, 03:58 PM
Dorsai's Avatar
Dorsai
Dorsai is offline
We tried the same thing last year on my '80 F-150 to clean out the tank...dropped it, put gasoline and chain in it, sloshed it around for a while, and reinstalled. It also looked good, but when I rebuilt my carburetor a few months ago I was still able to spoon the powdered rust out of the bowl.
So sometime this winter I will replace the tank. I've learned that if you've got rust in the tank, just buy a new one and save yourself trouble.
Old 01-15-2012, 04:22 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Agreed. If it was still running you got lucky. Mine plugged the acc pump nozzles, twice.
Old 01-15-2012, 05:14 PM
critterf1's Avatar
critterf1
critterf1 is offline
Replace the tank. Cheaper in the long run, easier on the nerves, also.
Old 01-15-2012, 05:20 PM
kedwinh's Avatar
kedwinh
kedwinh is offline
Around here a couple or the radiator shops will boil them out and re-coat the inside. Found that out when I bought an old Goldwing several years ago. Just another option.
Old 01-15-2012, 07:02 PM
RyansFord10
Thanks for the help everyone. I will go out to Autozone and buy a new one. I dont necessarily need one right now but i would still like to have it just in case.
Old 01-17-2012, 04:49 PM
Boss08v10's Avatar
Boss08v10
Boss08v10 is offline
I just put a new rear tank in my 94 short bed that I bought from JC Whitney, Like $70 bucks and found a free shipping promo code. It seems to be a great tank fro the money. Local Oreilly auto had them in stock for $110
Old 01-17-2012, 05:19 PM
Cavstoy's Avatar
Cavstoy
Cavstoy is offline
I just did both tanks in my 86 for 160 from auto parts warehouse (online). Shipping was free. Tanks seemed to be very high quality. Getting the rear lines on was a real pain in the butt.
Old 01-17-2012, 08:48 PM
Pkupman82's Avatar
Pkupman82
Pkupman82 is offline
I recently replaced the tank in my 84 F250 with one of the plastic replacement tanks from Bronco Graveyard. It cost a little more than the steel unit, but it will outlast the truck.
77_f250_custom
05-19-2015 11:27 PM
Hyperactive460
Paint & Bodywork
11-24-2013 09:46 AM
Apollo1
11-20-2008 08:15 AM
73BlackBeauty
11-12-2008 05:00 PM
rhw
17
04-19-2007 12:24 PM
Quick Reply: Aftermarket Gas Tank
