intermittent prob shifting out of park
Old Jan 15, 2012 | 12:49 AM
jjdoyle's Avatar
jjdoyle
i have a 2005 excursion diesel 4x4 that has developed an intermittent problem with shifting out of park. i have to push the brake pedal almost through the floor to get the transmission out of park. sometimes i have to push and release a couple times. the frequency seems to be increasing, but still is not constant. Master cylinder? shift interlock solenoid? electrical?
Old Jan 15, 2012 | 03:11 PM
EX40's Avatar
EX40
I would venture to say it's your brake light switch located on the brake pedal shaft. I've replaced on on an expedition & repaired on a Mustang. Same symptoms. No problems with my Ex though.
Old Jan 15, 2012 | 03:28 PM
jjdoyle's Avatar
jjdoyle
Thanks, I'll check that out.
Old Jan 15, 2012 | 08:54 PM
robert_l_ross's Avatar
robert_l_ross
x2. I had the same problem on my Expy...they designed the wires to run behind the brake pedal without enough room so the wires "flexed" every time I hit the brakes...eventually wearing them out at the switch connector.
I fixed it by pulling the connector off of a 150 and splicing it in to be long enough to secure with no flexing. I would imagine the same fix could be applied here. I never took time to check my Excursion...better do that tomorrow!
Old Jan 15, 2012 | 10:12 PM
jjdoyle's Avatar
jjdoyle
Thanks, sounds like everything starts with that switch and its wires
Old Jan 15, 2012 | 11:53 PM
robert_l_ross
I should have specified - that was my fix on my Expedition...not sure if the switch is different on the 150 series vs. the 250/350 series.
baller9409
Oct 13, 2012 09:24 PM
rungunner
May 6, 2011 07:54 PM
tow2atm
Dec 19, 2010 12:53 PM
Paxdad
Feb 25, 2010 09:22 AM
EZTrader
1978 - 1996 Big Bronco
Sep 10, 2003 10:38 AM
