Sponsored by: Real Truck
Brake troubles
Old Jan 14, 2012 | 12:07 PM
MWIZ's Avatar
MWIZ
Brake troubles
2008, f250, Gas. Brake pedal travels waaaay too far for my comfort. Took it in and they replaced the master cylinder. I didn't think it was any better, but the service tech. said it was fine. He has one and mine was way better than his. Where should I start? Vacuum booster or brake bleed or rear brake adjusting. Any input is appreciated.
Old Jan 14, 2012 | 05:37 PM
tonefordays's Avatar
tonefordays
First off, are your brakes in good shape, no excessive wear on pads or rotors? If all is good, I'd start with a thorough bleeding. Make sure all air bubbles are removed. I'd start there before tearing into things.
Old Jan 14, 2012 | 06:04 PM
MWIZ's Avatar
MWIZ
Yep. Pads and rotors are fine. Trucks only got 16000 miles on it. I will start with bleeding. Thanks.
Old Jan 14, 2012 | 08:06 PM
charbaugh's Avatar
charbaugh
Definitely start with bleeding. When you do the master cylinder, you have to bleed to all 4 calipers, and I have seen mechanics try and take a short cut and claim that you didn't need to because they left the fluid in the line. True enough, but when removing the master cylinder, you introduce air into all 4 lines, and bubbles can quickly work their way down.
mhbell
Apr 24, 2018 10:39 AM
roguewave
2009 - 2014 F150
Jan 20, 2018 01:06 PM
subzero32
Sep 21, 2016 06:35 AM
shetluck
Sep 11, 2015 11:13 PM
Shanemh
Mar 9, 2012 05:34 AM
