Replacing a camshaft need help
Old Jan 14, 2012 | 03:44 AM
bigtank250's Avatar
bigtank250
I Am going to replace my camshaft and needed to know if it's not to bad of a job ANC any tips or ways to do it? I have a 86 f250 7.5 460 big block 2wd
Old Jan 14, 2012 | 07:20 AM
Franklin2's Avatar
Franklin2
It's a pretty involved job, I am wondering why you are doing it. Pull the carb/intake, pull the valve covers, take all the rocker arms and pushrods out(keep them in order) pull all the stuff off the front of the engine, pull the radiator, and you might even have to pull the A/C condensor out of the way if you do not have enough room to slide the cam out. The hardest part sometimes is getting the lifters out, they get a varnish on them and get stuck in the lifter bores. They make a special puller for them.
Old Jan 14, 2012 | 09:36 AM
ctubutis's Avatar
ctubutis
Yes, it's a big job, and you'll need to pull the engine if you find you also need to replace the cam bearings.
Old Jan 14, 2012 | 11:09 AM
Sw1tchfoot's Avatar
Sw1tchfoot
If you have any oil leaks you might as well pull the entire engine and buy a complete gasket set.
danmansjimmy
Aug 15, 2007 10:08 PM
bigdan1979f-250
Oct 19, 2006 10:53 AM
Nathane
Feb 14, 2006 05:17 PM
Georgian
Oct 22, 2004 08:04 AM
KJKozak2
Apr 21, 2003 08:22 AM
