1978 - 1996 Big Bronco
If you're replacing window motors..
  #46
Old 06-17-2012, 07:00 AM
b4hntn's Avatar
b4hntn
b4hntn is offline
HA! Seeing in the door is not required. However, if one had REALLY big hands or forearms it would be very hard to reach the motor through the openings.
  #47
Old 06-17-2012, 07:40 AM
AzPete's Avatar
AzPete
AzPete is offline
Originally Posted by GruesomeJeans
Boy i would hate to do this... It is bad enough trying to diagnose my passenger side window crank system. I can't fit my fat head in the holes in the inside metal to see all the moving parts...
Mirrors and lights........and look from the top with the seals removed....... Sometimes it is easier to just remove the crank system....fix it....and install it again.
  #48
Old 06-17-2012, 12:56 PM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
yeah... I just loaded the mech down with a hinge grease so that kinda helped. The problem was the crank is really hard to roll down and half as hard up. But spraying that grease stuff seemed to help a bit.
Javier89F150
07-23-2015 01:43 PM
PsD007.3
11-15-2009 12:15 AM
v6mustangman
05-07-2006 06:51 PM
yankeenica
03-16-2004 10:54 PM
Quick Reply: If you're replacing window motors..
