Aftermarket Products
Sponsored by: Worksport
upgrade
Old Jan 13, 2012 | 09:46 AM
roddog101's Avatar
roddog101
upgrade
Hello all,
I have a 98 f250 light duty 4x4 4.6l and want to up grade the performance. When I am going to the white mountains and climb those canyon roads I can't get it passed 50 mph with an empty load. not hauling anything. I was wondering if I should get a throttle body spacer? Will that help?
Old Jan 13, 2012 | 10:18 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
A spacer isn't going to increase your cu in displacement...... what you need is a bigger engine. What are you towing?
Old Jan 13, 2012 | 11:30 AM
roddog101's Avatar
roddog101
I am not towing anything at this point might get me a 25 ft pull travel trailer.
I just don't like how it doesn't let me get past 50mph going up hill.
I want to add a little more power.
I was also thinking about a cold air intake an a flow master or magna flow muffler. then later a tuner chip?
Old Jan 15, 2012 | 11:02 AM
Beechkid's Avatar
Beechkid
With regards to “Chips” and “Tuners”, years ago it was the best that most could do to enhance the ignition timing, fuel curve, transmission shift points, etc. It was (and still is) very important that a person verifies that the “Tuner” is ASE certified in both ECM and Transmission programming and IMHO be have current certification by the OEM whose vehicle you want to modify. There are plenty of persons who advertise their programs to be the best and even offer custom tunes, but in all reality, very few actually have credentials in these areas- but that’s not to say that some of these “geniuses” haven’t really caused damage to a few vehicles- just jump over to flatratetech.com and read just some of the comments from the MSE techs!. Perhaps what is equally important is the parameters that can be adjusted are set by the OEM vehicle software…so there is really no “magic” in what they are doing anyway. Now about this new marketing hype that if you have a CAI you need a custom program………….hogwash!!!!!! The OEM software system is designed to adjust the fuel mixture up to 10%.......that’s more than enough to handle fuel mixture adjustments up to 7,000 foot elevation change! (for high elevations 8,000+ there are oem software programs for those specific applications) The 5.4 V8 for example if close to stock can only suck in a maximum of 480 cfm and a flat panel filter will flow 500 cfm, there is simply no way any CAI on a relatively stock engine can increase the air flow enough to exceed the ECM’s ability to adjust and maintain the correct fuel mixture. The only reason for the “custom” program to support the CAI is because the design is poor resulting in false readings from the air intake sensors, etc….period! If you look at the dyno charts from many of these supposed HP/TQ increases, they are typically around 5%-7% at peak rpm ranges…….guess what, 5% is a standard deviation even amoungst mfg dynos and the most important item is……these “expert tuners” (at least most) do not have or choose not to test their results (in comparison to the oem intakes) during actual vehicle motion (or simulation- such as a wind tunnel) as the oems do. If you look at the flow data, WIX HP filters flow 98+% of K&N and have a much smoother flow post filter plus excellent filtering, for a fraction of the price! The OE’s have an excellent air intake system.What many view as an issue (is the plastic intake tube with its noise canceling design) actually increases air pressure. It is the same hydraulic concept used by fire fighters creating water supply where psi is low. By having the air cross the path at a 90 degree angle, the pressure is increased proportionally. Fire fighters use what is called a “4-way valve” or “Blake Valve” at the hydrant where the water is cycled through the fire engine (pump) and sent back into the valve crossing the water flow at a 90 degree angle. In this case it also acts as a sound canceling device! At low speeds, this can reduce the flow a tad (which is what most “feel”), but in terms of peak hp/tq, a good high flow filter is all that is needed.
Recently, Testand Corporation conducted an ISO standards test on automotive air filters which can be viewed at this link: http://www.dieselbombers.com/chevrol...r-testing.html. All I can say is this explains in detail the reason for
(Arlen) SPICER wrote,
“Now that I am not doing the tests and my objectivity is not necessary, let me explain my motivation. The reason I started this crusade was that I was seeing people spend a lot of money on aftermarket filters based on the word of a salesperson or based on the misleading, incomplete or outright deceiving information printed on boxes and in sales literature"
IMHO, if you live near any major city there are excellent tuning specialists with dynos who for the same price (if not less) will tune your vehicle taking into consideration your specific needs including environmental conditions, for your specific vehicle. IMHO, the best bang for the buck!
You also have to remember, for every 5,000 foot elevation increase you loose 1/5 of the hp/tq.........your issue could be programming (requiring the oem high alititude upgrade), a component issue or, just normal operating condition.
jaal2012
2004 - 2008 F150
Aug 28, 2013 08:24 PM
DrewE05
Air Intakes, Air Filters & Ram Air
36
Feb 18, 2013 09:04 PM
fordfarmer12
Modular V8 (4.6L, 5.4L)
Dec 27, 2011 10:42 PM
badradio
2004 - 2008 F150
Dec 8, 2011 05:19 AM
droldsmorland
Computer Chips & Tuners
Nov 30, 2011 10:29 AM
