390 Stroker
Old Jan 12, 2012 | 08:54 PM
1972RedNeck's Avatar
1972RedNeck
390 Stroker
I am looking into building a 390 with a longer stroke. I would like to go at least to 4.125. What is the longest stroke I can go to without having to clearance the block? Also, can I use my stock 6.49 rods and get pistons with the right pin height for them? I am building this for a truck so it won't need to rev over 4500. I just want torque and lots of it.
Old Jan 12, 2012 | 09:35 PM
Sleepy445FE's Avatar
Sleepy445FE
You could run a 4.375" crank and you MIGHT have to grind a bit on the rod shoulders but it's only offered in a forged version I believe. Way overkill for what you want though. The cast Scat 4.25" would be better. The stroker kits use a 6.7" BBC rod and journal and a 1.33" compression height Probe or Diamond piston. I'd check out Survival Motorsports. Their kits come internally balanced and ready to go, no guess work on parts. That's where I got mine from and Barry will do you right. From a google search there's also Coast High performance. I don't have any feedback on them as I don't know of anyone that has purchased a kit from them.
Old Jan 13, 2012 | 09:31 AM
puttster's Avatar
puttster
I think the tough part will be finding the pistons. I have heard of folks being able to put similar packages together and then machining off the piston tops to fit. Need to do some serious measuring though.
As for contracting with specific out of state builders, sone have good experiences with it but strangely there are plenty of people here who post how great this stuff is even though they never actually bought it themselves!
puttster
Old Jan 13, 2012 | 10:21 AM
MIKES 68 F100's Avatar
MIKES 68 F100
LIKE SLEEPY SAID check out survival comes as a kit , no guessing at parts going to work .
Old Jan 13, 2012 | 12:00 PM
MeanGene427's Avatar
MeanGene427
Barry's kits are done deal, ready to install, complete balanced assembly. The 445 runs very strong, and bang for the buck champion. He also has a wide selection of hydraulic roller cams, tell him what you have and he'll recommend the right stuff
Old Jan 13, 2012 | 03:16 PM
jchamp429's Avatar
jchamp429
Update on Survival motorsports 445 stroker kit. I talked to barry yesterday and scat finally got some more cranks made. He is expecting to get them in at his shop some time in the next couple days.
Old Jan 15, 2012 | 03:18 PM
1972RedNeck
If the pistons were available I would like to buy them and a crank. I have a set of refurbished rods my brother gave me. If I have to, I will buy the kit(I don't think anybody will have to twist my arm).
Old Jan 15, 2012 | 05:19 PM
Sleepy445FE
The 4.25 stroker cranks use BBC rod journals (2.2). Much smaller than the FEs. The two aren't compatible.
Old Jan 15, 2012 | 08:06 PM
1972RedNeck
I guess I'll be "forced" to buy the kit.
Old Jan 15, 2012 | 09:07 PM
keisha9's Avatar
keisha9
so would you put the kit together or let a machine shop do it . Or do the work and let the shop verify everything is within specs?
Old Jan 16, 2012 | 08:46 PM
1972RedNeck
I will probably buy Survival Motorsports' kit. If it doesn't take any clearancing I will do it myself. I have a block with a fresh bore. I will plastic-gauge all the bearings and make sure It doesn't roll over to hard. I also know someone who works at a machine shop so if I need help I can get it.
thehobbyguy
24
Aug 21, 2011 08:30 AM
Trippa
Mar 8, 2008 11:22 AM
debestuss
17
Mar 15, 2005 03:00 PM
Mud_Hunter
20
May 30, 2004 11:47 AM
Rat wagon
15
Feb 21, 2003 01:09 PM
