Is the turn signal unit the same on a '79 manual transmission as a '77 automatic transmission? I picked one up from the '79 to replace my busted one since the steering wheel was already off at the junkyard, but I'm not really sure if the auto tranny with the column shifter makes it different.
Take a close look at it and you may want to spend a little time matching wires. It may just be that the only difference is the addition of bulb and wires for the gear selector indicator. I think the return portion is the same.
Edit: Well after reading your post again it looks like the JY truck was the manual shift so at the very least you may not have the light
Is the turn signal switch the same on a '79 manual transmission as a '77 automatic transmission? No!
Not only are A/T switches different from M/T switches, but...1973/77 F100/350's use different steering columns than 1978/79's.
1973/77 F100/350 & 1975/77 Econoline:
D3TZ-13341-A .. T/S Switch-Use with M/T / 1975/77 w/o Speed Control / Obsolete
Over 300 available NOS from Ford Dealers, obsolete parts vendors.
---------------------------------------------------------------- D3TZ-13341-B .. T/S Switch-Use with A/T / 1975/77 w/o Speed Control / Available from Ford.
MSRP: $69.98 // Contact FTE sponsor PARTSGUYED.COM for the discount price.
----------------------------------------------------------------------------- D5TZ-13341-B .. T/S Switch-1975/77-Use with Speed Control only / Obsolete
5 available NOS
1978/79 F100/350, Bronco & Econoline:
D8TZ-13341-A .. T/S switch-Use with Tilt Wheel / Obsolete
17 available NOS
---------------- D8TZ-13341-B .. T/S Switch-Use with A/T w/o Tilt Wheel / Available from Ford.
MSRP: $110.00 // Contact FTE sponsor PARTSGUYED.COM for the discount price.
------------------------------------------------------------------------------ D8TZ-13341-C .. T/S Switch-Use with M/T w/o Tilt Wheel / Obsolete
Provided the plastic ears are just broken you can replace that part of the switch with this part. Usually on the fix-it rack at most auto parts store for about $12.00. Not extremely difficult to put in but the existing wires end up very short cutting the old one out....
