Pulley whining.
Old Jan 12, 2012 | 06:49 AM
midsouth's Avatar
midsouth
Pulley whining.
On my 83, f150 4X4 5.8l, I can hear the alternator pulley beginning a whining sound...like the bearings need grease. Can I spray it with lubricant? Also, how am I to figure the belt tension if the alternator and/or pulley need replacement?
Old Jan 12, 2012 | 11:36 AM
Leaf's Avatar
Leaf
Standard Disclaimer: I may not have any idea what I am talking about.
AFAIK, most all bearings are supposed to be packed with bearing grease. Using a spray lubricant will break down the grease and accelerate wear. It may help in the short term, but will do more damage in the long term.
I think you probably want to either repack your bearings (maybe not possible if they are sealed bearings, and even if they're not it would probably take a very troublesome alternator disassembly) or just replace the whole thing with a cheap rebuilt one.
Old Jan 12, 2012 | 01:22 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Do not spray the bearing it will make it worse in the long term and could cause damage to the brushes inside.
You can try and spray the belt lightly with lubricant or belt dressing and if the noise goes away then changing the belt or adjusting the tension might help.
Old Jan 12, 2012 | 01:25 PM
midsouth's Avatar
midsouth
Thanks, I'll give that a go.
Old Jan 12, 2012 | 06:11 PM
bob_351's Avatar
bob_351
as said above if you spray belt dressing (ive also heard a bar of soap wiped on the belt) and the sound goes away its not the alternator or bearing. another thing that it could be is the alternator, i had a 98 blazer that had a whiney alternator, if i dissconected the battery lead off the alternator (not off the battery) the noise would go away
Buck268
Modular V8 (4.6L, 5.4L)
Jun 6, 2013 09:10 AM
ebraunusa
Jul 21, 2009 10:20 AM
billj6
1983 - 2012 Ranger & B-Series
Jun 8, 2009 03:29 AM
waynaferd
Oct 19, 2007 10:33 PM
mrgn_mtt
Jun 12, 2007 05:24 PM
