4x4 indicator light always on
Old Jan 11, 2012 | 09:19 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
My indicator light wont change from 4x4. Doesn't matter if ih 4 low, neutral 2 high. And yes it is shifting between the different settings. Its a manual floor shift. Any ideas what is wrong.? Thanks
Old Jan 11, 2012 | 11:24 PM
redman84's Avatar
redman84
Did it just start? LED lighting by chance?
Old Jan 12, 2012 | 09:50 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
This weekend. I had to change the bar between the shift lever and transfer case lever back to the original one so the shift lever would line up with the notches. I don't use 4x4 much anyways but the transfer case lever is moving through the different stages. Must be a sensor some where in the transfer case but could it always show 4x4?
Old Jan 13, 2012 | 11:50 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Any hints or suggestions what might be wrong? Is the sensor easy to get to to change? Thanks.
Old Feb 16, 2012 | 11:54 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Update, it seemed to correct its self, maybe because I don't use it much and the rod from the lever to the T case was not the right one, and now the original is back on so it is engaging at the correct positions it just needed some use to get it cleaned or something.
IDIDieselJohn
Jan 2, 2013 06:01 PM
cwt7691
Sep 19, 2007 06:20 AM
roadtech
Dec 12, 2005 10:32 PM
BillF150XLT
1997 - 2003 F150
Jun 24, 2003 06:06 AM
