Sponsored by: Real Truck
having trouble..... again
Old Jan 11, 2012 | 02:33 PM
2003 f-250's Avatar
2003 f-250
My truck is:
2003 ford F-250 4x4 with a 5.4 and a 6 sp manual
Well, today I had some trouble with my truck miss firing again. I thought that I had somehow burnt out another plug, but I was wrong. When I finally got home the codes were
P0625
"Knock s1 ckt (b1)"
and
P1151
"lack of ho2s- 21 switches- sensor indicates lean (b2,s1)"
Can anyone explain these to me?
My truck is stock except for a 3" exhaust (the p.o. removed the cat before I got the truck) and I have mike's 87 tow tune from 5 star.
Old Jan 11, 2012 | 02:34 PM
2003 f-250's Avatar
2003 f-250
Just FYI, I was on my way home from delivering a load of straw when the cel light came on, but it acted up a couple of different times when loaded. The trailer and straw together weigh about 11,000lbs.
thanks,
Robert
Old Jan 12, 2012 | 01:04 PM
2003 f-250's Avatar
2003 f-250
no suggestions?? When I searched, the people with the knock sensor code had a couple other codes that I did not get. And the people with the lack of ho2s code hade an odb II code about incomplete check (which I didn't get).
Thanks,
Robert
Old Jan 12, 2012 | 04:24 PM
FineSeventyNine's Avatar
FineSeventyNine
Tennessee Hillbilly
Boy that works for me has a 150 but it's a 5.4.....he had a similar problem..turned out to be the coil pack for #1 cylinder. IIRC he said that the dealer told him that if you washed the engine frequently they would get corroded? I ran AE on it but I think the code was something like #1 cylinder misfire detected?? I have a diesel so I'm not real familiar but I would take a look a the coil packs/wires.
Old Jan 12, 2012 | 04:46 PM
2003 f-250's Avatar
2003 f-250
coil packs/plugs/ect have less than 5000 miles.
thanks though
Robert
Old Jan 12, 2012 | 04:59 PM
FineSeventyNine
Tennessee Hillbilly
thanks though
Robert
No problem...next..what about your injectors?
Old Jan 12, 2012 | 05:05 PM
2003 f-250's Avatar
2003 f-250
about 5000 miles ago I had missfires that I couldn't figure out. @ that time the injectors were fine. The truck runs normal right now, just the one occasion of no power( I pulled over b/c I thought I had a flat but when I took off again the truck ran fine) and a couple of times with the missfire(about 10 sec each time)
Old Jan 12, 2012 | 09:20 PM
true blue's Avatar
true blue
Well, those codes indicate a lean condition which would mean low fuel mixture to air ratio. Look at injectors or maybe fuel pressure. There are sensors that would cause this too.
scott the jensen
Modular V8 (4.6L, 5.4L)
Sep 21, 2014 02:11 PM
Psygnosis
Jun 7, 2013 10:53 AM
mike L
General Automotive Discussion
Jan 9, 2013 09:54 PM
4dkidzboo
Escape & Escape Hybrid
13
Jan 9, 2012 01:56 PM
graydonricker
1997 - 2003 F150
Sep 16, 2011 09:35 PM
