Hydroboost Leak
Old Jan 11, 2012 | 07:00 AM
wolfman08's Avatar
wolfman08
Hydroboost Leak
No luck in the superduty forum so I hope to get some help here. I probably should have posted here first anyway since everyone here has the system.
I have a fluid leak coming from the hydroboost where it extends through the firewall. Fluid drips down onto my floormat right behind the brake pedal. Brakes are good and no leaks on the outside....just inside the cab.
I've found a couple of "rebuild" kits online but instructions and information on the procedure are hard to find. Anyone have any suggestions?
Thanks in advance.
2002 F350 4x4 7.3
<!-- / message -->
<!-- controls -->
Old Jan 11, 2012 | 11:58 AM
Vinford's Avatar
Vinford
[quote=wolfman08;11267551]No luck in the superduty forum so I hope to get some help here. I probably should have posted here first anyway since everyone here has the system.
Thanks in advance.
2002 F350 4x4 7.3
I got the same truck with the same problem.
My carpet is soaked on the top , its been that way for a year.
<!-- / message -->
<!-- controls -->
Old Jan 11, 2012 | 02:50 PM
wolfman08's Avatar
wolfman08
Guess I'm not the only one.
From my research, it looks like it's very common for the hydroboost to leak inside and outside on GM vehicles, but there is not much out there on Ford problems. I expect they're very similar or even the same units. I think I'm going to get the rebuild/reseal kit and see what I can come up with.
Old Jan 11, 2012 | 03:31 PM
F250_'s Avatar
F250_
Keep us posted on your discovery process and outcome.
Hitagain
Jan 5, 2017 06:15 PM
iron1951
Jul 25, 2014 09:24 AM
sudsmcduff
Aug 29, 2013 08:27 PM
wycowboy
Jan 1, 2008 09:57 AM
miller_feed
Sep 14, 2007 12:03 PM
