dana 50 questions
Old Jan 10, 2012 | 10:51 AM
MudPuppy91's Avatar
MudPuppy91
dana 50 questions
hey yall im nick and im new on this forum,
alrt so the deal is i picked up a d50 to SAS in my 91 ranger. i know the weaknesses and downsides of a 50 compared to a d60. however my question is (knowing the 50 uses a 60 housing) would it be cheaper to bore the tubes, put 60 inner C's on it, and line bore the carrier bearing seats in order to run 60 internals...or just buy a 60? and the general price for around my area is anywhere of 900+ for a front kingpin 60. ive put no money into the 50 except for an axle trade +200.
any help would be appreciated thankyou
Old Jan 10, 2012 | 03:01 PM
grandmas77f150's Avatar
grandmas77f150
My plan is to run D44HD front and D60 rear from the 70's era Fords.
But talking about the D50 specifically, I don't know how much it would cost to do that work, but if it were me, I'd hold out for a D60
Old Jan 10, 2012 | 08:51 PM
cj06's Avatar
cj06
what did the D50 come out of ?
and are you talking about putting it under the small ranger trucks or a regular sized ford truck ?
i think the D50 used the D44 housing with the D60 outers !
Old Jan 11, 2012 | 10:50 AM
MudPuppy91's Avatar
MudPuppy91
im putting it in a 91 ranger excab with 60 rear. but the 50 uses a 60 housing im pretty sure because theres plenty of room to stuff a 60 ring gear/carrier in the pumpkin
Old Jan 11, 2012 | 11:07 AM
cj06's Avatar
cj06
the D50 is not a weak axle by any means ! are planning to run mega HP and giant tires ?
the D50 should be fine as is !
depends on what year the axle is there might be a difference in the wheel bolt patterns !
Old Jan 11, 2012 | 11:42 AM
MudPuppy91's Avatar
MudPuppy91
its out of a 99 or a 2000. im converting it to 8x6.5 and spacing it out a little bit. im not planning on running anything bigger than 37-38's
Old Jan 11, 2012 | 11:55 AM
cj06's Avatar
cj06
then i would leave it alone and you should be good to go for a long time !
Old Jan 11, 2012 | 02:40 PM
MudPuppy91's Avatar
MudPuppy91
alrt cool deal. are flattops offered for the 50 by chance?
Old Jan 11, 2012 | 03:29 PM
grandmas77f150
Since you aren't doing an engine swap you should be fine.
I plan on running a carbed 460 out of the 70's era Fords, so hopefully the D44HD will hold up
Old Jan 11, 2012 | 09:02 PM
MudPuppy91's Avatar
MudPuppy91
im going to do a sbf 400 eventually with a np435/np241or
Old Jan 11, 2012 | 09:31 PM
cj06's Avatar
cj06
what are flat tops for the 50 ?
i am lost on that one , my thought was a hair cut when you turned 50 years old !
Old Jan 12, 2012 | 02:21 PM
MudPuppy91's Avatar
MudPuppy91
haha flattop knuckles for the dana 50. or does the d50 use d44 knuckles
Old Jan 12, 2012 | 07:37 PM
cj06's Avatar
cj06
the hubs are D60 so i think that the knuckles are also !
Old Jan 12, 2012 | 08:01 PM
MudPuppy91's Avatar
MudPuppy91
awesome thats even better. thanks bud.
i made a new post but ill include it in this one as well since this one has been goin for a little bit.
i want to use leaf springs all the way around and was wondering if anyone has any good advice on donor vehicle springs that wouldnt interfere with the front wheelbase being changed
Old Jan 12, 2012 | 08:33 PM
grandmas77f150
I see a lot of people using Chevy 63" or Deaver leaves for the rear.
I would just get leaves from Skyjacker for the front
huntersmith57
Apr 12, 2009 08:47 AM
hc130flyboy
Apr 28, 2005 11:39 AM
windyhill
Jul 6, 2004 10:05 PM
150ford
Apr 23, 2004 01:18 PM
RRMike
Apr 6, 2003 08:41 PM
