steering
Old Jan 9, 2012 | 08:21 PM
racinray's Avatar
racinray
steering
New member lots of questions,put a 74 model frontend under my 68 to get powersteering and disc brakes.Problem is my steering is way to easy no sensitivity how can I get more road feel?
Old Jan 9, 2012 | 09:16 PM
Ford_Six's Avatar
Ford_Six
That's 70s power steering unfortunately. I know on GMs you can change out the torsion spring to adjust the steering effort, I'm not sure if you can do something like that on the Ford boxes though.
Old Jan 9, 2012 | 09:37 PM
racinray's Avatar
racinray
could a shock dampner help any?
Old Jan 10, 2012 | 12:41 AM
moonley's Avatar
moonley
Get an alignment, you most likely need more caster.
A couple of options, other than cutting and rotating parts on the axle tube are:
1. Add caster shims under the spring pack:
http://www.4wheelparts.com/Lift-Kits...=101&t_pt=5502
2. Or add adjustable caster shims such as:
SPC Dodge/Ford Camber/Caster Sleeves - JEGS
Both options are only good for a couple degrees of caster, but it does make a difference.
Your current setup is probably only giving you 1-3 degrees of caster. You should have 6-8 degrees for your power steering to work well.
Old Jan 10, 2012 | 04:52 AM
jowilker's Avatar
jowilker
If I may, You have a huge change and driving it is the best way to get what you are looking for. I believe it's there, but not being used to it, you don't feel it.
John
Old Jan 10, 2012 | 06:11 PM
racinray's Avatar
racinray
Actually I did this several years ago and just gave up on fixing it.Have spent several hundred dollars at alignment shops.It has 6degrees of castor now and is so sensitive handling I will not let anyone else drive it.What is the maximum amount of castor you can get away with?
Old Jan 10, 2012 | 08:58 PM
HIO Silver's Avatar
HIO Silver
Heidt's offers an adjustable power steering valve to reduce the line pressure: Heidts PS-101 - Heidts Adjustable Power Steering Valves - Overview - SummitRacing.com
ap48379
Jan 2, 2019 04:34 PM
GJCAT
Large Truck
Nov 23, 2013 12:12 AM
MadF100
Aug 28, 2003 07:04 AM
Texan1983
Aug 14, 2003 10:08 PM
Racerdave
Dec 25, 2002 11:10 PM
